301H0EA
HP ENVY Laptop 17-cg1279ng
Intel® Core™ i7-1165G7 (up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores)
Intel® Integrated SoC
32 GB DDR4-3200 SDRAM (2 x 16 GB)
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
43.9 cm (17.3") diagonal 4K UHD display
Keyboard
Full-size, backlit, natural silver keyboard with numeric keypad
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 AC smart pin; 1 headphone/microphone combo
39.9 x 25.9 x 1.93 cm
Starting at 2.73 kg
90 W Smart AC power adapter
4-cell, 55.67 Wh Li-ion polymer
Battery life mixed usage
Up to 9 hours and 30 minutes
Video Playback Battery life
Up to 10 hours
HP Wide Vision 720p HD camera with camera shutter and integrated dual array digital microphones
Audio by Bang & Olufsen; Dual speakers; HP Audio Boost
