HP Designjet Printers - Product Comparisons
The following documentation was created to give a "like" platform for comparing any two HP Designjet printers, even if they are not from the same target market. Using the attached charts you can compare items such as Sizes, Electronics, Ink & Media Specs, Product Line Placement, Accessories, Languages and Connectivity, and basic Printer Features without referring to numerous sources.
HP Designjet 5500 series printers
รูปภาพ : 5500 series
Models, sizes, usage and markets
Models:
  • Q1251A (5500 42-inch)
  • Q1253A (5500 60-inch)
  • Q1252A (5500ps 42-inch)
  • Q1254A (5500ps 60-inch)
  • Q1251V (5500 UV 42-inch)
  • Q1253V (5500 UV 60-inch)
  • Q1252V (5500ps UV 42-inch)
  • Q1254V (5500ps UV 60-inch)
Available sizes:
  • 42 inch and 60 inch
Duty cycle:
  • 25-30 prints per day
Primary market:
  • Graphics market
Languages and connectivity
  • Supported Printing Languages - HPGL/2 + RTL, CALS G4, PostScript (on PS units)
  • Language Upgrades - n/a
  • Connectivity - LPT, Jetdirect card
  • Postscript RIP - HW RIP on PostScript models
Ink and media specifications
  • Number Of Ink Systems - 6 Colors, cmCMYK
  • Print Path - Flat Print Platen
  • PH Nozzles - 512 Nozzles
  • Swath Path - 1 Inches Wide
  • Drop Volume - Dye (cmCMYK) 12pl, UV (cmCMYK) 18pl
  • PH Technology - Embedded Smart Chip
  • UV Inks - Standard or as an Upgrade
  • Ink Level Sensing - Drop Counting, Smart Chip Tracking, Embedded Resistance Coils
  • Ink Composition - Imaging Inks - Dye, UV Inks - Pigment
  • Cartridge Volume - 680ml
  • PH Warranty/Duty Cycle - 700ml or 9000hrs
  • Dots-Per-Inch - 600 True, 1200 Addressable
Electronics
  • Memory - Non-PostScript models 42-inch and 60-inch (128 MB), PostScript models (42-Inch, 128 MB), (60-Inch, 196 MB), Max Upgrade (256 MB)
  • Storage - Non-PostScript models (20 GB), PostScript models (40 GB)
  • Main PCA CPU Speed - 392MHz
  • Writing System - Photo RET 3, Color Smart 3
  • Front Panel Display - LED Display
  • Configuration - Menu Based Configuration
  • Automatic Calibrations - Printhead Alignment, Color Calibrations, Pantone Calibration (PS models)
  • Firmware - Boot ROM SIMM, FW Stored on HD, Flashable via SW Utility
  • Required SIMMs - Boot ROM SIMM, Memory
Features
  • Quality Assurance - Drop Detector, Fault Tolerant Printing
  • Media Paths - Single Sheet Feed, Roll Feed
  • Paper Control - Vacuum System
  • Priming System - Automatic, Forced Air
  • Margin Control - Smaller, Normal, Extended
  • Refill System - Tube Fed
  • Remote Access - Jetdirect Information, Advanced Printer Information, Remote Job submittal
  • Stand and Media Bin - 42 Inch (Stand and Media Bin), 60 Inch (Stand and Take-Up Reel)
  • Roll Feed - Standard
  • Queuing and Nesting - Standard
  • Standby Mode - Standard
  • Miscellaneous - Interchangeable Tube Systems, Supports both UV and Dye IDS’s, Remote Job Submittal, Direct Print Path for TIFF, PDF, EPS, JPG, and CALS G4 Prints, Permanent File Storage, Heater, Production Print Mode, Upgradeable Media Profiles, Pantone Compliant, Altitude Control, 300ft Roll Support, Media Length Tracking
Product line placement
  • Unit replaces - CP Series, 5000 Series
  • Replaced by - None
Available accessories
  • Memory - 64 MB SIMM 128 MB SIMM
  • Connection - n/a
  • Paper Handling - Take up Reel for 42 Inch, Media Bin for 60 Inch
  • Ink Upgrades - UV or Dye Upgrades, Printhead Garage (Humidor)
  • Maintenance Kits - Available as an On-Site Service
HP Designjet 5000 series printers
รูปภาพ : 5000 series
Models:
  • C6090A (5000 42-inch)
  • C6095A (5000 60-inch)
  • C6091A (5000ps 42-inch)
  • C6096A (5000ps 60-inch)
  • C6090V (5000 UV 42-inch)
  • C6095V (5000 UV 60-inch)
  • C6091V (5000ps UV 42-inch)
  • C6096V (5000ps UV 60-inch)
Available sizes:
  • 42-inch and 60-Inch
Duty cycle:
Primary market:
  • Graphics market
  • Postscript RIP - HW RIP on PS models
  • Ink Composition: Imaging Inks - Dye, UV Inks - Pigment
Electronics
  • Storage - Non-PostScript models (5 GB), PostScript modes (20 GB)
Features
  • Margin Control - Normal, Extended
  • Remote Access - Jetdirect Information, Basic Printer Information
  • Miscellaneous - Interchangeable Tube Systems, Supports both UV and Dye IDS’s, Upgradeable Media Profiles, Pantone Compliant, Altitude Control, 300ft Roll Support, Media Length Tracking
  • 5000 series replaces - CP Series
  • Replaced by - 5500 Series
  • Memory - 64 MB SIMM, 128 MB SIMM
  • Connection - n/a
HP Designjet 1000 series printers
รูปภาพ : 1000 series
Models:
  • C6074A (1050C)
  • C6075A (1055CM)
  • C6074B (1050C plus)
  • C6075B (1055CM plus)
Available sizes:
  • 36-Inch
Duty cycle:
Primary market:
  • CAD market
  • Supported Printing Languages - HPGL/2 + RTL, HPGL, CALS G4, PostScript (on PS units)
  • Language Upgrades - PS Upgrade
  • Number Of Ink Systems - 4 Colors, CMYK
  • Swath Path - 0.85 Inches Wide
  • Drop Volume - Black (34pl), CMY (12pl)
  • UV Inks - n/a
  • Ink Composition: Black (Pigment) CMY (Dye)
  • Cartridge Volume - 350ml or 175ml
  • Dots-Per-Inch - 600 (True), 1200 (Addressable (Mono))
Electronics
  • Memory - 1050C and 1055CM (32 MB), 1050C plus (64 MB), 1055CM plus (128 MB), A Model Max Upgrade (128 MB), B Model Max Upgrade (256 MB)
  • Storage - 1050C (Optional 2 GB Ext), 1055CM (Standard 2 GB Ext), 1050C plus (Optional 2 GB Ext), 1055CM plus (Standard 7.5 GB Int)
  • Main PCA CPU Speed - 98MHz
  • Writing System - Standard, Non-Photographic
  • Firmware - SIMM
  • Required SIMMs - Firmware, Memory
Features
  • Media Paths - Dual Sheet Feed and Roll Feed
  • Remote Access - Jetdirect Information only
  • Stand and Media Bin - Standard
  • Standby Mode - N/A
  • Miscellaneous - Self-Aligning Media, Ink Leak Detection, Automatic Ink Limiting, Open Loop Color Control, Temperature Sensor on Board, Humidity Sensor on Board, 300ft Roll Support
  • 1000 series replaces - 700 Series
  • Replaced By - None
  • Memory - A Model (32 MB SIMM, 64 MB SIMM), B Model (64 MB SIMM, 128 MB SIMM)
  • Firmware - Postscript Upgrade Kit
  • Connection - N/A
  • Paper Handling - Optional Multi-roll Feeder, Optional Take-Up Reel
  • Ink Upgrades - N/A
HP Designjet 800 series printers
รูปภาพ : 800 series
Models:
  • C7779B (800 24-inch)
  • C7780B (800 42-inch)
  • C7779C (800ps 24-inch)
  • C7780C (800ps 42-inch)
Available sizes:
  • 24-inch and 42-Inch
Duty cycle:
  • 15 prints per day
Primary market:
  • CAD market
  • Supported Printing Languages - PCL3GUI, HPGL/2 + RTL, CALS G4, PostScript (on PS models)
  • Language Upgrades - N/A
  • Connectivity - LPT, USB, Jetdirect card
  • PH Nozzles - 304 Nozzles
  • Swath Path - 0.5 Inches Wide
  • Drop Volume - Black (18pl), CMY (4pl)
  • UV Inks - N/A
  • Ink Composition: Black (Pigment), CMY (Dye)
  • Cartridge Volume - 69ml
  • PH Warranty/Duty Cycle - Black (530ml), CMY (200ml)
  • Dots-Per-Inch - 600 (True), 1200 (Addressable)
Electronics
  • Memory - 800 (96 MB), 800ps (160 MB), 800 Max Upgrade (160 MB)
  • Storage - 800 (Standard 7 GB), 800ps (Standard 7 GB)
  • Main PCA CPU Speed - 96MHz
  • Firmware - EEPROM, Flashable via SW Utility
  • Required SIMMs - Memory
Features
  • Quality Assurance - Manual
  • Priming System - PEG Applicator in SSTN
  • Stand and Media Bin - 24 Inch (Optional), 42 Inch (Standard)
  • Miscellaneous - Rear Loading Roll, Lightweight Aluminum Frame, Altitude Control
  • 800 series replaces - 700 Series, 400 Series
  • Memory - 128 MB SODIMM
  • Connection - N/A
  • Paper Handling - Stand and Media Bin (24 Inch)
HP Designjet 500 series printers
รูปภาพ : 500 series
Models:
  • C7769B (500 24-inch)
  • C7770B (500 42-inch)
Available sizes:
Duty cycle:
  • 15 prints per day
Primary Market:
  • CAD market
  • Supported Printing Languages - PCL3GUI, HPGL/2 + RTL (w/card), PostScript (PS models w/SW RIP)
  • Connectivity - LPT, USB, Jetdirect card (optional)
  • Postscript RIP - SW RIP on PS models
  • UV Inks - N/A
Electronics
  • Memory - 500 (16 MB on Main PCA), 500ps (16 MB on Main PCA), 500 Max Upgrade (160 MB), 500ps Max Upgrade (160 MB)
  • Storage - N/A
  • Required SIMMs - None
Features
  • Queuing and Nesting - Reprint Last Job
  • Memory - 16 MB on HPGL/2 Card, 64 MB SODIMM, 128 MB SODIMM, HPGL/2 Card required for upgrade, optional HPGL/2 Card (16 MB)
  • Connection - Optional Jetdirect card
HP Designjet CP series printers
รูปภาพ : CP series
Models:
  • C4703A (2000CP)
  • C4704A (2500CP)
  • C4723A (3000CP)
  • C4724A (3500CP)
  • C6085A (2800CP)
  • C6084A (3800CP)
Available sizes:
  • 2x00CP (36-Inch), 3x00CP (54-Inch)
Duty cycle:
  • 15 prints per day
Primary market:
  • Graphics market
  • Supported Printing Languages - HPGL/2 + RTL, HPGL, CALS G4, PostScript (2500CP, 3500CP)
  • Postscript RIP - HW Fiery Rip (2800CP and 3800CP), HW RIP on PS models
  • Print Path - Curved Drive Roller
  • PH Nozzles - 240 Nozzles
  • Swath Path - 0.4 Inches Wide
  • Drop Volume - Dye (CMYK, 21pl), UV (CMYK, 26pl)
  • PH Technology - Passive, No Smart Chip
  • UV Inks - Yes
  • Ink Level Sensing - Drop Counting, Printhead Resisters
  • Ink Composition: Imaging Inks (DYE), UV Inks (Pigment)
  • PH Warranty/Duty Cycle - CMYK (350ml)
Electronics
  • Memory - 2000CP, 2800CP (16 MB), 3000CP, 3800CP (16 MB), 2500CP, 3500CP (32 MB), CP Max Upgrade (64 MB)
  • Storage - 2500CP (2 GB HD), 3500CP (4.3 GB HD)
  • Main PCA CPU Speed - 22MHz
  • Writing System - Standard, Photographic
  • Firmware - SIMM
  • Required SIMMs - FW, Memory
Features
  • Quality Assurance - Printhead Check System, Fault Tolerant Printing
  • Paper Control - Bail System
  • Refill System - Automatic via Refill Assembly
  • Stand and Media Bin - 2x00 (Standard Legs and Tray), 3x00 (Standard Legs and Tray), 3x00 (Standard Take-Up Reel)
  • Miscellaneous - Pantone Compliant
  • CP series replaces - None
  • Replaced by - 5000 Series, 5500 Series
  • Memory - 16 MB SIMM, 32 MB SIMM
  • Connection - 2000, 2800CP (Optional Jetdirect), 3000, 3800CP (Optional Jetdirect)
  • Paper Handling - 2x00CP (Optional Take-Up Reel)
  • Ink Upgrades - UV Upgrade Kits, Printhead Garage (Humidor)
HP Designjet 700 series printers
รูปภาพ : 700 series
Models:
  • C4705A/C4706A (700)
  • C4705B/C4706B (700 B)
  • C3195A/C3196A (750C)
  • C4708A/C4709A (750C Plus)
  • C4708B/C4709B (750C Plus B model)
  • C3198A (755CM)
  • C3198B (755CM B model)
บันทึก
A Model (700, 750C, 755CM), B Model (750Cplus, 755CMplus)
Available sizes:
  • 24-inch and 36-inch
Duty cycle:
  • 10 - 20 prints per day
Primary market:
  • CAD market
  • Supported Printing Languages - HPGL/2 + RTL, HPGL, PostScript (on PS models)
  • Language Upgrades - PS Upgrade Available
  • PH Nozzles - Black (304 Nozzles), CMY (96 Nozzles)
  • Swath Path - 0.48 Inches Wide
  • Drop Volume - Unknown
  • UV Inks - N/A
  • Ink Level Sensing - Cartridge Indicator
  • Cartridge Volume - 42ml
  • PH Warranty/Duty Cycle - 42ml
  • Dots-Per-Inch - 600 True (Mono), 600 Addressable (Color)
Electronics
  • Memory - A Models (8 MB (700+750C)), A Models (68 MB (755CM)), A Model Max Upgrade (64 MB), B Models (8 MB (700+750C+)), B Models (72 MB (755CM+)), B Model Max Upgrade (72 MB)
  • Storage - N/A
  • Main PCA CPU Speed - 14MHz
  • Firmware - SIMM
Features
  • Refill System - Cartridge Replacement
  • Stand and Media Bin - 24 Inch (Optional), 36 Inch (Standard)
  • Miscellaneous - 755CM Pantone Compliant
  • 700 series replaces - 600 Series
  • Replaced by - 1000 Series, 500/800 Series
  • Memory - 4 MB SIMM, 8 MB SIMM, 16 MB SIMM, 32 MB SIMM
  • Connection - 700, 750C and 750Cplus (Optional Jetdirect)
HP Designjet 400 series printers
รูปภาพ : 400 series
Models:
  • C4713A/C4714A (430)
  • C4715A/C4716A (450C)
  • C6080A/C6081A (455CA)
  • C6082A/C6083A (488CA)
Available sizes:
Duty cycle:
  • 10 prints per day
Primary market:
  • CAD market
  • Connectivity - LPT, Serial
  • PH Nozzles - 96 Nozzles
  • UV Inks - N/A
  • Dots-Per-Inch - 300 True, 600 Addressable (Mono)
Electronics
  • Memory - 4 MB
  • Storage - N/A
  • Main PCA CPU Speed - 4MHz
  • Front Panel Display - Lights
  • Configuration - Setup Sheet
  • Automatic Calibrations - None
  • Firmware - On Main PCA and SIMM
Features
  • Priming System - Manual, Forced Air
  • Margin Control - None
  • Remote Access - N/A
  • Stand and Media Bin - Optional
  • Roll Feed - Optional
  • Queuing and Nesting - N/A
  • Miscellaneous - 430 is the only true Mono printer
  • 400 series replaces - 200 Series
  • Replaced by - 500/800 Series
  • Firmware - Optional Color Upgrade Kit
  • Connection - Optional Jetdirect (external)
  • Paper Handling - Optional Stand and Bin, Optional Roll Feed
ประเทศ/ภูมิภาค:
