Product Name
17-e163sg
Product Number
F7T36EA
AMD Quad-Core A10-4600M APU with Radeon HD 7660G Graphics (2.3 GHz, 4 MB cache)
AMD A76M FCH
Memory
12 GB 1600 MHz DDR3L SDRAM (1 x 4 GB, 1 x 8 GB)
Video Graphics
AMD Radeon HD 7660G/8670M Dual GPU (1 GB DDR3 dedicated)
Hard Drive
750 GB 5400 rpm SATA
Multimedia Drive
SuperMulti DVD burner
43.9 cm (17.3") diagonal HD BrightView LED-backlit (1600 x 900)
Network Card
Wireless Connectivity
802.11b/g/n (1x1)
Sound
DTS Sound+ with 2 speakers
Keyboard
Full-size island-style with numeric keypad
Pointing Device
External Ports
1 VGA 1 HDMI 1 headphone/microphone combo 1 USB 2.0 2 USB 3.0 1 RJ-45 |
Dimensions
42 x 26.7 x 3.28 cm
2.9 kg
Power
90 W AC power adapter
6-cell (47 WHr) Li-ion |
Camera
HP TrueVision HD Webcam (front-facing) with integrated digital microphone
