Display size
27"
Display type
VA
Panel active area(inches)
23.49 x 13.22 in
Panel active area(cms)
59.69 x 33.63 cm
Brightness
350 nits
Pixel Pitch
0.3114 mm x 0.3114 mm
Input connector
1 HDMI 2.0 (with HDCP support); 1 DisplayPort™ 1.4-in (with HDCP support)
Scan range (horizontal)
30-210 KHz
Scan range (vertical)
60-165 Hz
Recommended resolution
1920 x 1080 (FHD)
Aspect ratio
16:9
Static contrast ratio;Dynamic contrast ratio
3000:1
Response time
1ms MPRT (with overdrive)
Tilt
-5 to +20°
Internal
Power consumption
50 W (maximum), 25 W (typical), 0.5 W (standby)
Power supply
100 - 240 VAC 50/60 Hz
Dimensions
61.13 x 8.53 x 36.76 cm
6.6 kg
