6BH27EA
HP ENVY - 17-ce0001ns
Intel® Core™ i7 8565U (1.8 GHz base frequency, up to 4.6 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2400 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS anti-glare WLED (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 headphone/microphone combo; 1 RJ-45
40.5 x 26.6 x 2.25 cm
2.83 kg
65 W AC power adapter
3-cell, 52 Wh Li-ion
Battery life mixed usage
Up to 10 hours and 45 minutes
Video Playback Battery life
Up to 9 hours and 15 minutes
B&O, dual speakers, HP Audio Boost, HP Far-field Cortana support
