Both Production mode and High Quality mode offer an additional option called "Fine Text".
Fine Text changes the speed of the printer carriage to half of its normal rate. This allows for a
very accurate drop placement with very little overspray. This option can be used when printing
very small type and/or finely detailed lines, such as a map or similar output.
Because the speed of the carriage slows, the UV lamps spend more time over the media.
Some media react to the heat of the lamps by bowing. Be careful when selecting the Fine Text
option on media that are sensitive to heat. You may need to introduce a Printing Delay to allow
heat to dissipate from the media after each pass of the carriage.
