To turn the printer's buzzer on or off, go to the front panel's main menu and select the Setup menu icon , then Front panel options > Enable buzzer, highlight on or off and press the OK key. The default buzzer is set to on.
บันทึกFor safety reasons, the buzzer always sounds when the carriage beam is raised or lowered.
