This document describes fuser removal and replacement for the HP LaserJet 4200/4250/4300/4350 printer series.
คำเตือนThe fuser might be very hot. After turning off the printer power, allow the fuser to cool for at least 30 minutes before removing it.
บันทึกIf the duplexer is installed, lift it up slightly and pull it away from the printer to remove it.
หมายเหตุDo not drop or jar the fuser. It can easily be damaged if it is mishandled.
