Follow these steps to install the cartridges that shipped with your product.
Figura : Cartridges that shipped in the box
Locate the two slots on the left and right sides of the product.
Figura : Locate the two slots on the sides of the product
Slide your fingers into the two slots, and then lift up to open the cartridge access door. The carriage moves into the cartridge access area.
Figura : Open the cartridge access door
On one of the cartridges, pull the orange pull-tabstraight back to remove the plastic wrap.
Figura : Remove the plastic wrap
Twist the orange cap counterclockwise to snap it off the cartridge.
Figura : Remove the orange cap
Slide the cartridge into the correct slot as shown. The color-coded icons on the cartridge and in the printhead must match.
Figura : Insert the cartridge
Press down on the cartridge until it clicks firmly into place.
Figura : Press the cartridge into place
Repeat these steps for each cartridge.
Close the cartridge access door.
Figura : Close the cartridge access door
