This document contains specifications for the product, including model numbers, system requirements, and print speed.
All-in-One Model
Product Number
HP Officejet 6500 (E709a) All-in-One Printer
CB815A
CB838A
CB839A
CB841A
CB845A
CB860A
CM742A
HP Officejet 6500 (E709n) Wireless All-in-One Printer
CB057A
CB829A
CB830A
CB832B
CB836A
CB861A
CM741A
merknad:For Windows 2000 SP 4, Windows XP x64 Edition SP 1, Windows XP SP 1 Starter Edition, and Windows Vista Starter Edition only the print driver, scanner driver, and the Toolbox are available.
Component
Minimum system requirement
Recommended system requirement
Processor
Windows 2000 Service Pack 4
Intel Pentium II or Celeron processor
Intel Pentium III or higher processor
Windows XP (32-bit)
Windows XP x64
AMD Athlon 64 or AMD Opteron processor
Intel Xeon
or Pentium processor with Intel EM64T support
AMD Athlon 64 or AMD Opteron processor, Intel Xeon
or Pentium processor with Intel EM64T support, or Intel Pentium 4 processor with Intel EM64T support
Windows Vista and Windows 7
800 MHz 32-bit (x86) or 64-bit (x64) processor
1 GHz 32-bit (x86) or 64-bit (x64) processor
RAM
128 MB
256 MB
Windows XP (32-bit) OR Windows XP x64
512 MB
512 MB
512 MB
1 GB
Free disk space
200 MB
200 MB
Windows XP (32-bit)
410 MB
500 MB
Windows XP x64
290 MB
290 MB
425 MB
470 MB
Browser
Windows 2000 Service Pack 4, Windows XP (32-bit), Windows XP x64
Microsoft Internet Explorer 6.0 or later
Microsoft Internet Explorer 7.0 or later
Other
Adobe Acrobat Reader 5.0 or later
merknad:You can purchase a USB cable from any reputable dealer.
Component
Processor
Mac OS X 10.4, 10.5, and 10.6
PowerPC with G3, G4, G5, or
Intel Core Duo processor
OS X 10.7
Intel Core 2 Duo processor
Intel Core 2 Duo or higher processor
Memory
256 MB
512 MB or higher
OS X 10.7
2 GB
2 GB or higher
Browser
Any browser
Free disk space
500 MB
800 MB or higher
Other
CD-ROM or DVD-ROM drive
Available USB port and USB cable
Adobe Acrobat Reader 5.0 or later (recommended)
Quick Time 5.0 or later (recommended)
SVGA 800 x 600 monitor with 16-bit color (32-bit color recommended)
Internet access (recommended)
Component
Specification
Connectivity
USB support
USB 2.0-compliant high speed
Network support
Wireless 802.11 b/g (E709n model only)
Wired network
Product processor and memory
Product processor
192 MHz ARM946ES, ETM9 (medium)
Product memory
64 MB built-in RAM, 32 MB built-in Flash ROM
Font support
US fonts: CG Times, CG Times Italic, Universe,
Universe Italic, Courier, Courier Italic, Letter
Gothic, Letter Gothic Italic.
Dimension
Measurement*
Height
258 mm (10.3 inches)
Width
467 mm (19.0 inches)
Depth
473 mm (18.9 inches)
8.6 kg (19 pounds)
*Measurements are for product with A4/Letter-size scanner glass and duplexer.
Example
Printhead
Cartridge
Black
Europe
Middle East and Africa
Asia Pacific
HP 920XL* Black Officejet Cartridge
The Americas
HP 920 Black Officejet Cartridge
Cyan
Europe
Asia Pacific
HP 920XL Cyan Officejet Cartridge
The Americas
HP 920 Cyan Officejet Cartridge
Magenta
Europe
Asia Pacific
HP 920XL Magenta Officejet Cartridge
The Americas
HP 920 Magenta Officejet Cartridge
Yellow
Europe
Asia Pacific
HP 920XL Yellow Officejet Cartridge
The Americas
HP 920 Yellow Officejet Cartridge
Tray
Type
Capacity*
Input tray
Paper
60 to 105 g/m2 (16 to 28 lb bond)
Up to 100 sheets of plain
paper
(25 mm [1 inch] stacked)
Transparencies
n/a
Up to 70 sheets
(17 mm [0.67 inch]
stacked)
Photo paper
280 g/m2 (75 lb bond)
Up to 100 sheets (17 mm [0.67 inch]
stacked)
Labels
n/a
Up to 100 sheets
(17 mm [0.67 inch] stacked)
Envelopes
75 to 90 g/m2 (20 to 24 lb bond envelope)
Up to 30 sheets (17 mm [0.67 inch]
stacked)
Cards
Up to 200 g/m2 (110 lb index)
Up to 80 cards
Duplexer (Wireless models only)
Paper
60 to 105 g/m2
(16 to 28 lb bond)
n/a
Automatic Document Feeder (ADF)
Paper
60 to 105 g/m2
(16 to 28 lb bond)
Up to 35 sheets of plain paper
Up to 20 sheets of Legal and specialty paper
Output tray**
All
supported
media
n/a
Up to 150 sheets of plain paper (text printing)
Paper type
Paper size
U.S. Letter
216 x 279 mm (8.5 x 11 inches)
U.S. Legal
216 x 356 mm (8.5 x 14 inches)
A4
210 x 297 mm (8.3 x 11.7 inches)
U.S. Executive
184 x 267 mm (7.25 x
10.5 inches)
B5 (JIS)
182 x 257 mm (7.17 x 10.12
inches)
B5 (ISO)
176 x 250 mm (6.9 x 9.8
inches)
B7
88 x 12 5mm (3.5 x 4.9 inches)
A5
148 x 210 mm (5.8 x 8.3 inches)
Borderless A4
inches)
Borderless A5
inches)
Borderless B5
10.12 inches)
HV
101 x 180 mm (4.0 x 7.1 inches)
Cabinet size
120 x 165 mm (4.7 x 6.5
inches)
130 x 180 mm (5 x 7 inches)
Borderless cabinet
120 x 165 mm (4.7 x
6.5 inches)
Borderless
Paper type
Paper size
U.S. #10 Envelope
105 x 241 mm (4.12 x
9.5 inches)
DL Envelope
110 x 220 mm (4.3 x 8.7
inches)
C6 Envelope
114 x 162 mm (4.5 x 6.4
inches)
Japanese Envelope Chou #3
120 x 235
mm (4.7 x 9.3 inches)
Japanese Envelope Chou #4
90 x 205
mm (3.5 x 8.1 inches)
Paper type
Paper size
Index card
76.2 x 127 mm (3 x 5 inches)
Index card
102 x 152 mm (4 x 6 inches)
Index card
127 x 203 mm (5 x 8 inches)
A6 card
105 x 148.5 mm (4.13 x 5.83
inches)
Borderless A6 card
105 x 148.5 mm
(4.13 x 5.83 inches)
Hagaki
100 x 148 mm (3.9 x 5.8
inches)
Ofuku hagaki
200 x 148 mm (7.9 x 5.8 inches)
Borderless hagaki
100 x 148 mm (3.9 x
5.8 inches)
Paper type
Paper size
Photo paper
102 x 152 mm (4 x 6
inches)
Photo paper
127 x 178 mm (5 x 7 inches)
Photo paper
203 x 254 mm (8 x 10 inches)
Photo paper
254 x 381 mm (10 x 15 cm)
Photo L
89 x 127 mm (3.5 x 5 inches)
2L
178 x 127 mm (7.0 x 5.0 inches)
Borderless photo paper
102 x 152 mm
(4 x 6 inches)
inches)
Borderless Photo L
89 x 127 mm (3.5 x
5 inches)
Borderless 2L
inches)
Borderless B5
182 x 257 mm (7.2 x 10.1
inches)
Borderless B7
88 x 125mm (3.5 x 4.9
inches)
Borderless 4 x 6 tab
102 x 152 mm (4 x
6 inches)
Borderless 10 x 15 cm tab
100 x 150 mm (3.9 x 5.9 inches)
Borderless 4 x 8 tab
100 x 200 mm (3.9 x 7.9 inches)
Borderless HV
inches)
Borderless double A4
210 x 594 mm
(8.3 x 23.4 inches)
Paper type
Paper size
Custom-sized paper
Between 76.2 to
216 mm wide and 127 to 610 mm long
(3 to 8.5 inches wide and 5 to 24 inches
long)
Custom-sized paper (ADF)
Between
127 to 216 mm wide and 241 to 305 mm
long (5 to 8.5 inches wide and 9.5 to 12
inches long)
Panorama
4 x 10 inches, 4 x 11 inches,
and 4 x 12 inches
Borderless panorama
4 x 10 inches, 4 x
11 inches, and 4 x 12 inches
merknad:The device is compatible with plain and inkjet hagaki from Japan Post only. It is not compatible with photo hagaki from Japan Post.
Print Mode
Print speed
Black
Color
Draft
32
30
ISO
7
6
LQS
6
5
Print mode
Type
Scan resolution (dpi)
Best
Black
Up to 600 x 1200
Color
Up to 600 x 1200
Normal
Black
Up to 300 x 300
Color
Up to 300 x 300
Fast
Black
Up to 300 x 300
Color
Up to 300 x 300
Type
dpi setting
Very fine
Fine
Standard
Black
196 x 203 (8-bit
grayscale)
300 x 300
196 x 203
196 x 98
Color
200 x 200
200 x 200
200 x 200
200 x 200
merknad:Approaching any of the recommended maximums on a memory card might cause the performance of the device to be slower than expected.
