This kit includes replacement filters (twelve filters total). The filters cover the air vents above the
lamp bulbs (versus the filters above the lamp’s shutter motor). One filter is placed above each of
the two air vents. The filter will keep debris from entering the lamp bulb area. The filters should be
replaced after 100 hours of printer use or when the filters are clogged with debris.
Printer Orientation
Figur : Pertinent Printer Parts
Removing and Installing the Filter
Power off the printer following the steps outlined in the section “Managing Power Off Scenarios.”
Open a end door to access the carriage.
Unscrew the thumb screws to disconnect the power cables from the top of the lamp assemblies.
A scewdriver may be needed to loosen the thumb screws.
The lamp power cables must be removed because the safety tabs of the filter cover slide
beneath the power cable. If the filter cover does not have safety tabs, the power cables do
not need to be removed (as long as the printer is powered off).
Figur : The arrows indicate the thumb
screws to loosen
bemærk:
The photo shows the
carriage cover removed;
however, it is not necessary to
remove the cover for this
procedure
Using a small flat-blade screwdriver, pry the side of the cover up to remove the cover from the
lamp.
Figur : Technique to pry off lamp cover
On the side of the lamp air vent cover are two slots that can be used to pry off the cover of
the lamp assembly.
Remove the dirty filter.
Insert a clean filter over the lamp bulb air vents (A).
In the photo shown below, the shutter motor air vents (B) are not covered with a filter but
should be. If shutter motor air filters are needed, order kit 0901614.
Figur :
A = Lamp bulb filter
B = Shutter motor air vents
Clean the lamp cover with head flush.
Install the lamp bulb air vent cover in the orientations shown below, making sure the lip
around the cover faces upward.
Figur : The arrow indicates the cover lip
facing upward
Reconnect the UV power cables and tighten their thumb screws.
