Product Specifications for the HP OfficeJet Pro 9120b All-in-One Printer (4V2P0C)
Product naming
Model name
4V2P0C
Connectivity
Ports
1 Bluetooth Low Energy; 1 Hi-Speed USB 2.0 (device); 1 Hi-Speed USB 2.0 (host); 1 Wi-Fi 802.11 a/b/g/n/ac (dual band); 1 Ethernet; 2 RJ-11 Fax/Modem port/phone line
Wireless capability
Yes, built-in WiFi 802.11a/b/g/n/ac
Storage device and direct print support
Storage devices not supported
Copy
Copier settings
Copies; Two-Sided; Lighter/Darker; HP Copy Fix; ID Copy; Resize; Quality; Paper Size; Paper Type; Collate; Margin Shift; Crop; Copy Preview; Tray Select; Enhancements
Color copy capability
Yes
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed, black (draft, A4)
Up to 28 cpm
Copy speed, black (draft, Letter)
Up to 28 cpm
Copy resolution
Up to 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.8 B(A) (printing at 20ppm)
Acoustic pressure emissions
61 dB(A) (printing at 20ppm)
Recommended operating humidity range
25 to 75% RH
Recommended operating temperature range (Celsius)
15 to 32ºC
Recommended operating temperature range (Fahrenheit)
59 to 90ºF
Storage temperature range (Celsius)
-40 to 60ºC
Storage temperature range (Fahrenheit)
-40 to 140ºF
Environmental specifications
Recyclable through HP Planet Partners; Forest First product with HP+
Fax
Fax available
Yes, color
Fax Resolution Black (best)
300 x 300 dpi
Fax memory
Up to 100 pages
Telephone handset supported
No
Fax telephone mode supported
No
Modem
Synaptics Troy modem; Data rate up to 33.6 kbps
Fax Speed Dials, Maximum Number
No
Fax transmission speed (letter)
4 sec per page
Fax transmission speed note
Based on standard ITU-T test image #1 at standard resolution. More complicated pages or higher resolution will take longer and use more memory.
Memory
Memory
512MB
Maximum Memory
512 MB
Mobile printing capability
Mobile printing services
Apple AirPrint™; Wi-Fi® Direct Printing; HP Roam
Mobile printing compatibility note
App or software account registration may be required. Some features require purchase of an optional accessory. Learn more at http://www.hp.com/go/mobileprinting
Networking
Network protocols, supported
Supported Network Protocols configurations (IPv4, IPv6); DHCPv4, DHCPv6; DHCP options: 81/RFC4702/RFC4704, 12-Hostname; 44; SMTP client; LLMNR; Bonjour/mDNS; LP/ APIPA (Auto IP); NetBIOS/WINS; LPR/LPD; Port9100; DNS Resolver; SNMPv1/v2; Web Services Discovery; Web Services Print; Syslog; Firewall; SSL/TLS (HTTPS); Password-protected network Embedded Web server; Enable/disable network ports & device features, 802.1x wireless authentication (EAP-TLS, LEAP, and PEAP) & 802.1 Wired
Paper handling
Input capacity
Up to 250 sheets
Standard input capacity (cards)
Up to 50 sheets
Standard input capacity (envelopes)
Up to 30 sheets
Output capacity
Up to 60 sheets
Media sizes supported (metric)
A4, A5, A6, B5(JIS), Card (A4, Hagaki, Ofuku Hagaki); Photo (13 x 18 cm, 10 x 15 cm); Envelope (A2, C5, C6, DL. Chou #3, Chou #4); 8.5 x 13 in
Media sizes supported (U.S. standard)
Letter; Legal; Government Legal; Executive; Statement; 3 x 5 in; 4 x 6 in; 5 x 7 in; 13 x 18 cm; 8 x 10 in; 10 x 15 cm; L; Photo 2L; Envelope( #10, Monarch, 5.5 bar); Card (3 x 5 in, 4 x 6 in, 5 x 8 in)
Media sizes, custom (metric)
Tray 1: 76.2 x 127 to 215.9 x 355.6 mm
Media sizes, custom (U.S. standard)
Tray 1: 3 x 5 to 8.5 x 14; 5 x 8.3 to 8.5 x 14 in
Media types
Plain Paper, HP Photo Papers, HP Matte Brochure or Professional Paper, HP Matte Presentation Paper, HP Glossy Brochure or Professional Paper, Other Photo Inkjet Papers, Other Matte Inkjet Papers, Other Glossy Inkjet Papers, Thick Plain Paper, Light/Recycled Plain Paper, HP Tri-fold Brochure Paper, Glossy
Media weight supported (metric)
60 to 105 g/m² (plain); 220 to 280 g/m² (photo);  75 to 90 g/m² (envelope); 163 to 200 g/m² (card)
Media weight supported (U.S. standard)
16 to 28 lb (plain paper); 60 to 75 lb (photo);  20 to 24 lb (envelope); 90 to 110 lb (card)
Borderless printing
Yes, on photo paper only, up to 8.5 x 11 in (US letter), 210 x 297 mm (A4)
Paper handling - ADF
Automatic document feeder capacity
Standard, 35 sheets
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Letter; executive; Not supported for borderless photo
Physical dimensions
Maximum dimensions (W x D x H, metric)
439.3 x 519.8 x 278 mm (Output Tray Extend)
Maximum dimensions (W x D x H, U.S. standard)
17.3 x 20.46 x 10.94 in (Output Tray Extend)
Weight (metric)
~9.29 kg
Weight (U.S. standard)
~20.48 lb
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology
Internal (Built-in) Universal Power Supply
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz
Power consumption
5.06 watts (ready), 1.22 watts (sleep), 0.14 watts (manual-off)
Print cartridges
Number of print cartridges
4 (1 each black, cyan, magenta, yellow)
Replacement cartridges
HP 936 Black Original Ink Cartridge (~1450 pages) 4S6V2LN, HP 936 Cyan Original Ink Cartridge (~800 pages) 4S6U9LN; HP 936 Magenta Original Ink Cartridge (~800 pages) 4S6V0LN; HP 936 Yellow Original Ink Cartridge (~800 pages) 4S6V1LN; HP 936e EvoMore Black Original Ink Cartridge (~3,100 pages) 4S6V6LN; HP 936e EvoMore Cyan Original Ink Cartridge (~1,650 pages) 4S6V3LN; HP 936e EvoMore Magenta Original Ink Cartridge (~1,650 pages) 4S6V4LN; HP 936e EvoMore Yellow Original Ink Cartridge (~1,650 pages) 4S6V5LN; Actual yield varies considerably based on content of printed pages and other factors. For details, see https://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic
Print speed (black, draft, Letter)
Up to 32 ppm
Print speed (color, draft, Letter)
Up to 32 ppm
Print speed black (ISO)
Up to 22 ppm
Print speed color (ISO)
Up to 18 ppm
Print resolution (best)
1200 x 1200 rendered dpi
Maximum print area (metric)
216 x 356 mm (Legal)
Monthly duty cycle
Up to 25,000 pages
Print languages
HP PCL6, PCL5, native PDF, HP Postscript
Printer smart software features
Orientation: Portrait/Landscape/Rotate by 180 degrees; Print On Both Sides; None, Flip on Long Edge, Flip on Short Edge; Pages per sheet: 1 page per sheet/2 pages per sheet/4 pages per sheet/6 pages per sheet/9 pages per sheet/16 pages per sheet; Print Quality: HP Standard/Quick Draft/Premium/Detailed; RGB color: Printer Default/Office (sRGB)/Photo (sRGB)/Device RGB/Adobe RGB/Vivid (sRGB)/Custom RGB Printing Shortcuts; Factory Defaults; EcoSMART settings; Labels; CardStock/Heavy; Transparencies; Booklet Printing; General Everyday Printing; Page order: Front to Back/Back to Front/; Booklet Layout: Off/Left binding/Right binding;Print page borders; Special pages: Front cover/Back Cover/Print pages on different paper/Insert Blank Pages Resizing Options: Actual size/Print document on:/Scale manually Watermarks: None/Confidential/Draft/Sample/Custom Copies: Up to 99; Collate; Reverse page order; Print all text as black; Control Panel Shortcuts; HP EasyColor: Off/Conservative/Automatic Wireless
Regulatory specifications
Ecolabels
IT ECO Declaration; EPEAT® registered
Safety
IEC 60950-1:2005 +A1:2009 +A2:2013; IEC 62368-1:2014 EN 62368-1:2014 +A11:2017; IEC 62368-1:2018; EN IEC 62368-1:2020, EN IEC 62368-1:2020/ A11:2020; EN 62311:2008; EN 62479:2010; UL 62368-1 & CAN/CSA C22.2 No. 62368-1-14
Electromagnetic compatibility
CISPR 32:2015 / EN 55032:2015 Class B; CISPR 24:2010 / EN 55024:2010;  CISPR 35:2016 / EN 55035:2017+A11:2020; EN 61000-3-2:2014 / IEC 61000-3-2:2014; EN 61000-3-3:2013 / IEC 61000-3-3:2013; EN 301 489-1 V2.2.3; EN 301 489-17 V3.2.4; FCC CFR 47 Part 15 Class B ICES-003, Issue 7; Class B VCCI V-3:2015
Telecom compliance (fax capability)
FCC Rules and Regulations 47 CFR Part 68/ TIA-968-B ES 203 021-2 / ES 203 021-3; EN 301 893 V2.1.1; EN 300 440 V2.1.1; Radio Equipment Directive 2014/53/EU.
Scan
Scanner advanced features
Dual pass two sided scanning with Auto Document Feeder
Scan technology
Contact Image Sensor (CIS)
Scan speed (normal)
Up to 8 ipm (200 ppi, b&w); up to 8 ipm (200 ppi, color)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
215.9 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.7in
Minimum ADF scan size (metric)
127 x 127 mm
Minimum ADF scan size (U.S. standard)
5 x 5 in
Maximum ADF scan size (metric)
215 x 355mm
Maximum ADF scan size (U.S. standard)
8.5 x 14 in
Twain version
Version 2.4
Security
Security management
SSL/TLS (HTTPS); IPP over TLS; WPA2-Enterprise; WPA2-Personal; WPA3; Certificates configuration;  Password protect EWS; Signed firmware;
System requirements
Minimum system requirements for Windows
Windows 10,11: 32-bit or 64-bit, 2 GB HD, Internet required, Internet Explorer or Edge
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
Apple macOS v11Big Sure, macOS v12 Monterey, macOS v13 Ventura, 2 GB HD, Internet required
Recommended Macintosh system requirements
Compatible Network Operating Systems
Windows 11; Windows 10; Windows Server; macOS 11 Big Sur; macOS 12 Monterey; macOS 13 Ventura; Linux; Chrome OS
Operating system (supported note)
Windows Server 2016 64-bit, Windows Server 2019 64-bit, Windows Server 2022 64-bit, linux (for more information see http://developers.hp.com/hp-linux-imaging-and-printing)
Manufacturer Warranty
One-year limited warranty. For more information please visit us at http://support.hp.com [9]
