4R113UA
HP Tablet 11m-be0023dx
Intel® Pentium® Silver N6000 (up to 3.3 GHz burst frequency, 4 MB L3 cache, 4 cores, 4 threads)
Intel® Integrated SoC
4 GB LPDDR4x-4266 MHz RAM (onboard)
Video graphics (integrated)
Intel® UHD Graphics
128 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
11" diagonal, 2.1K (2160 x 1440), multitouch-enabled, IPS, edge-to-edge glass, Corning® Gorilla® Glass 5™, Low Blue Light, 400 nits, 100% sRGB
Intel® Wi-Fi 6 AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader
1 SuperSpeed USB Type-C® 5Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); Pogo connecting from slate to KB; Portrait pogo connection (5 PIN); Landscape pogo connection (5 PIN)
25.25 x 17.65 x 0.81 cm (tablet); 25.25 x 18.01 x 0.49 cm (soft cover); 25.18 x 17.65 x 0.41 cm (kickstand)
0.6 kg (tablet); 0.46 kg (soft cover and kickstand)
30 W USB Type-C® power adapter
2-cell, 32.2 Wh Li-ion polymer
Battery life mixed usage
Up to 6 hours and 45 minutes
Video Playback Battery life
Up to 9 hours and 30 minutes
HP True Vision 13MP rotatable camera with temporal noise reduction and integrated dual array digital microphones
Audio
Three speakers
