![HP ProDesk 400 G7 Small Form Factor PC](/wcc-assets/document/images/521/c06706206.jpg)
Feature
Pre-installed (Windows)
Windows 10 Pro 64 (National Academic License)
note: Windows 10 Pro 64 (recommended by HP)
Windows 10 Enterprise 64 (web support)
note: |
Pre-installed (other)
FreeDOS 1.2
note:In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Feature
Intel Core i7-10700 Processor
2.9 GHz Base frequency,
up to 4.7 GHz maximum turbo frequency with Intel Turbo Boost
Technology
16 MB cache, 8 cores, and 16 threads
Intel UHD Graphics 630
Supports DDR4 memory up to 2933 MT/s data rate
Supports Intel vPro Technology and Intel Stable Image
Platform Program (SIPP)
Intel Core i5-10600 Processor
3.3 GHz Base frequency,
up to 4.8 GHz maximum turbo frequency with Intel Turbo Boost
Technology
12 MB cache, 6 cores, and 12 threads
Supports DDR4 memory up to 2666 MT/s data rate
Intel Core i5-10500 Processor
3.1 GHz Base frequency,
up to 4.5 GHz maximum turbo frequency with Intel Turbo Boost
Technology
Intel Core i5-10400 Processor
up to 4.3 GHz maximum turbo frequency with Intel Turbo Boost
Technology
Intel Core i3-10320 Processor
3.8 GHz Base frequency,
up to 4.6 GHz maximum turbo frequency with Intel Turbo Boost
Technology
8 MB cache, 4 cores, and 8 threads
Intel Core i3-10300 Processor
3.7 GHz Base frequency,
up to 4.4 GHz maximum turbo frequency with Intel Turbo Boost
Technology
Intel Core i3-10100 Processor
3.6 GHz Base frequency,
Technology
6 MB cache, 4 cores, and 8 threads
Intel Pentium Gold G6600 Processor
4.2 GHz Base frequency
4 MB cache, 2 cores, and 4 threads
Intel Pentium Gold G6500 Processor
4.1 GHz Base frequency
Intel Pentium Gold G6400 Processor
4.0 GHz Base frequency
Intel UHD Graphics 610
Intel Q470
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Feature
Standard
Number of slots: (2) DIMM (customer accessible / upgradeable)
Up to 2666 MT/s and 3200 MT/s
note: |
Maximum
64 GB
Configurations
4 GB (4 GB x 1)
8 GB (4 GB x 2)
8 GB (8 GB x 1)
16 GB (8 GB x 2)
16 GB (16 GB x 1)
32 GB (16 GB x 2)
32 GB (32 GB x 1)
64 GB (32 GB x 2)
note: |
Feature
Integrated
Intel UHD Graphics 630 (for 10th gen Core i7/i5/i3 processors
and Pentium Gold G6600, and G6500)
Intel UHD Graphics 610 (for Pentium Gold G6400)
Discrete graphics (optional)
AMD Radeon R7 430 2 GB Graphic card 2 DP
AMD Radeon R7 430 2 GB Graphic card DP and VGA
AMD Radeon RX 550X 4 GB Graphic card DP and HDMI
Adapters and cables
HP DisplayPort Cable
HP DisplayPort to DVI-D Adapter
HP DisplayPort to HDMI True 4K Adapter
HP DisplayPort to VGA Adapter
HP USB to Serial Port Adapter
Feature
SATA Hard Disk Drives
500 GB 7200 RPM SATA HDD (3.5 in)
1 TB 7200 RPM SATA HDD (3.5 in)
2 TB 5400 RPM SATA HDD (3.5 in)
500 GB 7200 RPM SATA HDD (2.5 in)
1 TB 7200 RPM SATA HDD (2.5 in)
2 TB 5400 RPM SATA HDD (2.5 in)
500 GB 7200 RPM Self Encrypted OPAL 2 SATA HDD (2.5 in)
500 GB 7200 RPM Self Encrypted Federal Information Processing Standard SATA HDD (2.5 in)
note: |
Solid State Drives (SSD)
256 GB M.2 2280 PCIe NVMe SSD
512 GB M.2 2280 PCIe NVMe SSD
128 GB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe TLC SSD
512 GB M.2 2280 PCIe NVMe TLC SSD
1 TB M.2 2280 PCIe NVMe TLC SSD
256 GB M.2 2280 PCIe NVMe Self Encrypted OPAL 2 TLC SSD
512 GB M.2 2280 PCIe NVMe Self Encrypted OPAL 2 TLC SSD
256 GB Intel Optane Memory H10 with SSD
512 GB Intel Optane Memory H10 with SSD
note: |
Optical disc drive
HP 9.5 mm (0.37 in) Slim DVD-ROM Drive
HP 9.5 mm (0.37 in) Slim DVD Writer Drive
HP 9.5 mm (0.37 in) Blu-Ray Writer Drive
Media card reader
SD 4.0 Card reader with 5-in-1 interface
Supports SD, SDXC, SDHC, UHS-I, and UHS-II
note:For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 36 GB of system disk is reserved for the system recovery software.
Feature
Keyboard
HP PS/2 Business Slim Standalone Wired Keyboard
HP Wired Desktop 320K Keyboard
HP USB Business Slim Wired SmartCard CCID Keyboard
HP USB and PS/2 Washable Standalone Wired Keyboard
HP USB Wired Keyboard
HP Universal USB Wired Keyboard
Mice
HP PS/2 Mouse
HP Wired Desktop 320M Mouse
HP USB Optical Wired Mouse
HP USB Hardened Optical Wired Mouse
HP USB 1000dpi Laser Mouse
HP USB and PS/2 Washable Wired Mouse Standalone
HP USB Fingerprint Mouse
Keyboard and Mouse combo
HP USB PS/2 Washable Keyboard and Mouse Wired
HP Business Slim Wireless Keyboard and Mouse
note:Availability might vary by country/region.
Feature
High Definition Audio
Integrated Realtek ALC3205
(1) 3.5 mm Headset connector supports an OMTP or CTIA style headset and is re-taskable as a
Line-in, Line-out, microphone-in or headphone-out port
Rear Line-out and stereo support
note: 2 W per channel class D stereo amplifier (for internal speakers only)
Feature
Ports
(2) USB 2.0 Type-A ports (rear)
(2) USB 2.0 Type-A ports (front)
(3) USB 3.2 Gen 1 Type-A ports (rear) 5 Gbps signaling rate
(2) USB 3.2 Gen 2 Type-A port (front) 10 Gbps signaling rate
(1) RJ-45 (network) connector (rear)
(1) HDMI 1.4 input connector (rear)
(1) DisplayPort connector (rear)
(1) Microphone/headphone combo jack (front) CTIA and OMTP headset
support
(1) Internal M.2 PCIe
x4 2280 (for
storage)
x1 2230 (for
WLAN)
(1) Internal PCI Express Gen 3 x1
(1) Internal PCI Express Gen 3 x16
(3) Internal SATA port
Optional port 1 (any one)
(2) USB 3.2 Gen 1 Type-A 5 Gbps signaling
rate port
(1) USB 3.2 Gen 2 Type-A 10 Gbps signaling rate
port with DisplayPort
Alt Mode
(1) DisplayPort 1.4 or
HDMI 2.0 or VGA port
Optional port 2 (any one)
(1) Serial (RS-232) port
Slot
(1) SD media card reader (front)
Bays
(1) 9.5 mm Slim Optical Disc Drive
(2) 6.35 cm (2.5 in) Internal storage drive
(1) 8.89 cm (2.5 in) Internal storage drive
note: |
Feature
Ethernet (RJ-45)
Intel I219-LM Gigabit Network Connection (standard)
Intel I210-T1 PCIe x1 Gigabit Network Interface Card (optional)
note: |
Wireless
Intel Wi-Fi 6 AX201 802.11ax (2x2) with Bluetooth M.2 Combo Card vPro
Intel Wi-Fi 6 AX201 802.11ax (2x2) with Bluetooth M.2 Combo Card non-vPro
Realtek RTL8822CE 802.11ac (2x2) with Bluetooth M.2 Combo Card
Realtek RTL8821CE 802.11ac (1x1) with Bluetooth M.2 Combo Card
note: |
Feature
BIOS
HP BIOSphere Gen6 (available on select platforms)
BIOS Update via Network
Power On Authentication
Master Boot Record Security
HP Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
Absolute Persistence Module
note: |
HP Value add software
HP Desktop Support Utility
HP Privacy Settings
HP Setup Integrated OOBE
HP Image Assistant
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Management Integration Kit Gen4 for Microsoft SCCM (available for download)
HP Cloud Recovery (client tool available for download)
Ivanti Management Suite (available for download)
Security
HP Client Security Manager Gen5 (requires Windows and available on select platforms)
Windows Defender (opt in and internet connection required for updates)
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Intrusion Sensor (optional)
Other standard security features
Intel Identify Protection Technology (IPT)
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
HP Sure Click (available on select HP platforms and supports Internet Explorer, Google
Chrome, and Chromium)
HP Sure Sense (requires Windows)
Support for chassis padlocks and cable lock devices
Feature
External power supplies
180 W active PFC
80
PLUS Gold
87/90/87% efficient at
20/50/100% load
(115 V)
90/92/89% efficient at
20/50/100% load
(230 V)
210 W active PFC
80
PLUS Platinum
20/50/100% load
(115 V)
91/93/90% efficient at
20/50/100% load
(230 V)
note: |
Feature
Dimensions (W x D x H)
269.24 x 302.26 x 93.98 mm (10.6 x 11.9 x 3.7 in)
3.9 kg (8.6 lb)
note: |
