Your computer features top-rated components. This chapter provides details about your components, where they are located, and how they work.
Right side
Use the illustration and table to identify the components on the right side of the computer.
![Identifying the right-side components](/wcc-assets/document/images/643/c06685400.jpg)
Component
(1)
nano SIM card slot (select products only)
Supports a wireless subscriber identity module (nano SIM) card.
note: note:
(2)
USB Type-C® power connector and Thunderbolt™ ports (2) with HP Sleep and Charge
Connect an AC adapter that has a USB Type-C connector, supplying power to the computer and, if needed, charging the computer battery.
- and -
Connect a USB device, provides high-speed data transfer, and charges small devices, even when the computer is off.
- and -
Connect a display device that has a USB Type-C connector, providing DisplayPort™ output.
note: note: |
(3)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High-Definition Multimedia Interface (HDMI) device.
(4)
Battery light
When AC power is connected:
When AC power is disconnected (battery not charging):
(5)
Power connector
Connects an AC adapter.
Left side
Use the illustration and table to identify the components on the left side of the computer.
![Identifying the left-side components](/wcc-assets/document/images/127/c06685404.jpg)
Component
(1)
Security cable slot
Attaches an optional security cable to the computer.
note: |
(2)
USB SuperSpeed port with HP Sleep and Charge
Connects a USB device, provides high-speed data transfer, and charges small devices, even when the computer is off.
(3)
USB SuperSpeed port
Connects a USB device, provides high-speed data transfer, and (for select products) charges small devices when the computer is on or in Sleep mode.
(4)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
warning: note: |
(5)
Smart card reader
Supports optional smart cards.
The computer display can include essential components such as speakers, antennas, cameras, and microphones.
![Identifying the display components](/wcc-assets/document/images/762/c06685409.jpg)
Component
(1)
WLAN antennas* (select products only)
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
(2)
Camera light(s)
On: One or more cameras are in use.
(3)
Internal microphones
Record sound.
(4)
Camera (select products only)
Allows you to video chat, record video, and record still images. Some cameras also allow a facial recognition logon to Windows, instead of a password logon.
note: |
(5)
Camera privacy cover
By default, the camera lens is uncovered, but you can slide the camera privacy cover to block the camera's view. To use the camera, slide the camera privacy cover in the opposite direction to reveal the lens.
note: |
(6)
Ambient light sensor (select products only)
Adjusts the brightness of the display, depending on the ambient light.
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
To access this guide:
Keyboard area
Keyboards can vary by language.
Touchpad components
Use the illustration and table to identify the touchpad components.
To adjust touchpad settings and gestures, or to turn off the touchpad:
Type touchpad settings in the taskbar search box, and then press enter.
Choose a setting.
To turn on the touchpad:
Using an external mouse, click the touchpad button.- or -
Press the Tab key repeatedly until the pointer rests on the touchpad button. Then press the spacebar to select the button.
![Identifying the touchpad](/wcc-assets/document/images/484/c06685410.jpg)
Component
(1)
Touchpad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(2)
Left control zone
Textured area that allows you to perform additional gestures.
(3)
Right control zone
(4)
Near Field Communications (NFC) tapping area and antenna (select products only)
Allows you to wirelessly share information when you tap it with an NFC-enabled device.
Lights
Use the illustration and table to identify the lights on the computer.
![Identifying the lights](/wcc-assets/document/images/611/c06685411.jpg)
Component
(1)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(2)
Privacy key light (select products only)
On: Privacy screen is on, which helps prevent side-angle viewing.
(3)
Fn lock light
On: The fn key is locked.
(4)
Mute light
(5)
Microphone mute light
(6)
Power light
Button, speakers, and fingerprint reader
Identify the computer button, speakers, and fingerprint reader.
Fingerprint readers can be located on the touchpad, on a side panel of the computer, or on the top cover below the keyboard.
note:To verify that your computer supports fingerprint reader sign-in, type Sign-in options in the taskbar search box and follow the on-screen instructions. If Fingerprint reader is not listed as an option, then your notebook does not include a fingerprint reader.
![Identifying the button, vent, speakers, and fingerprint reader](/wcc-assets/document/images/222/c06685416.jpg)
Component
(1)
Speakers (2)
Produce sound
(2)
Power button
note: If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button down for at least 4 seconds to turn off the computer.
To learn more about your power settings, see your power options:
(3)
Fingerprint reader (select products only)
Allows a fingerprint logon to Windows, instead of a password logon.
Special keys
Use the illustration and table to identify the special keys.
![Identifying the special keys](/wcc-assets/document/images/349/c06685417.jpg)
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes frequently used system functions when pressed in combination with another key. Such key combinations are called hot keys.
(3)
Windows key
Opens the Start menu.
note: |
(4)
Action keys
Execute frequently used system functions.
(5)
Programmable key
Executes frequently used tasks. Some tasks might not be available on all products.
(6)
Power button
Hot keys (select products only)
A hot key is the combination of the fn key and another key. Use the table to identify the hot keys.
To use a hot key:
Press the fn key, and then press one of the keys listed in the following table.
Key
C
Turns on scroll lock.
E
Turns on the insert function.
R
Breaks the operation.
S
Sends a programing query.
W
Pauses the operation.
Bottom
Use the illustration and table to identify the bottom component.
![Identifying the bottom component](/wcc-assets/document/images/325/c06685420.jpg)
Component
Vent
Enables airflow to cool internal components.
note: |
Labels
The labels affixed to the computer provide information that you might need when you troubleshoot system problems or travel internationally with the computer. Labels can be in paper form or imprinted on the product.
note:Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
Service label—Provides important information to identify your computer. When contacting support, you might be asked for the serial number, the product number, or the model number. Locate this information before you contact support.Your service label information order may vary by country and might not include the wording "Model" due to the country regulation.
Service label components Component(1)HP product name(2)Product ID(3)Serial number(4)Warranty period -
Regulatory label(s)—Provide(s) regulatory information about the computer.
Wireless certification label(s)—Provide(s) information about optional wireless devices and the approval markings for the countries or regions in which the devices have been approved for use.
