![HP Chromebox Enterprise G2](/wcc-assets/document/images/553/c06469192.png)
Feature
Preinstalled
Chrome OS
Chrome Enterprise Upgrade embedded
Intel Core i7-8650U
1.9 GHz, up to 4.2 GHz
4 cores
8 threads
Intel Core i5-7300U
2.6 GHz, up to 3.5 GHz
2 cores
4 threads
Intel Core i3-7130U
2.7 GHz
2 cores
4 threads
Intel Celeron 3867U
1.8 GHz
2 cores
2 threads
Intel Celeron 3865U
1.8 GHz
2 cores
2 threads
Integrated with processor
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Feature
Integrated
Intel HD Graphics 610 (3865U and 3867U)
Intel HD Graphics 620 (i5-7300U, i3-7130U, and 7-8650U)
Feature
Standard
DDR4-2400 SDRAM (transfer rates up to 2400 MT/s)
Supported
4 GB
8 GB
16 GB
note:Shared video memory (UMA) uses part of the total system memory for video performance. System memory dedicated to video performance is not available for other use by other programs.
Feature
Internal storage
M.2 SATA-3 2242
32 GB SSD
M.2 SATA-3 2280
64 GB SSD
note: |
Removable storage
MicroSD card slot
Feature
Audio
Realtek ALC5662-CG
Internal beeper
Specification
Ports
Front
(1) Headphone/microphone combo jack
(2) USB 3.0 Type-A
Back
(2) USB 3.0 Type-A
(1) USB 2.0 Type-A
(1) USB Type-C (power connector and charging port)
(1) RJ45/Ethernet
(1) HDMI version 1.4b
(1) AC input
Slots
(1) MicroSD card slot (push-pull type) (front)
Feature
Wired Gigabit Ethernet (GbE)
RTL8151GH-CG
Wi-Fi and Bluetooth
Intel Dual Band Wireless-AC 7265 802.11a/b/g/n/ac (2x2) Wi-Fi and Bluetooth 4.2 Combo (non-vPro)
note: |
Specification
Power supply
External 65 W adapter
85% efficiency
100-240 V
50-60 Hz
External 90 W adapter
85% efficiency
100-240 V
50-60 Hz
note: |
Primary cord
1.8 m (5.90 ft)
Specification
Dimension (W x D x H)
149.3 x 149.3 x 40.0 mm (5.88 x 5.88 x 1.57 in)
570 g (1.26 lb)
Specification
Contents
External power supply
Quick start guide
