Feature
Preinstalled
Windows 10 Pro 64 (recommended by HP)
Windows 10 Pro for Workstations 64
FreeDOS 1.2
Windows 10 China Government Edition
Web supported
Red Hat Enterprise Linux (REHL) 7
note:Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Intel Core i5-9300H
2.4 GHz
Up to 4.1 GHz with Intel Turbo Boost Technology
8 MB cache, 4 cores
Intel UHD Graphics 630
Intel Core i5-9400H vPro
2.5 GHz
Up to 4.3 GHz with Intel Turbo Boost Technology
8 MB cache, 4 cores
Intel Core i7-9750H
2.6 GHz
Up to 4.5 GHz with Intel Turbo Boost Technology
12 MB cache, 6 cores
Intel Core i7-9850H vPro
2.6 GHz
Up to 46 GHz with Intel Turbo Boost Technology
Intel Core i9-9880H VPro
2.3 GHz
Up to 4.8 GHz with Intel Turbo Boost Technology
16 MB cache, 8 cores
Intel Xeon E-2286M vPro
2.4 GHz
Up to 5.0 GHz with Intel Turbo Boost Technology
Intel UHD Graphics P630
Integrated with processor
Intel Core i5/Core i7/Xeon with vPro technology capable
Intel Virtualization Technology (Intel VT)
Intel Active
Management Technology (iAMT)
note: |
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.Intel Turbo Boost is based on maximum GHz for a single core.
Feature
Integrated
Intel UHD Graphics 630 (configurable as a standalone graphics option)
note: |
Discrete
NVIDIA Quadro T1000 with 4 GB dedicated GDDR5 video memory
NVIDIA Quadro RTX3000 with 6 GB dedicated GDDR6 video memory
NVIDIA Quadro RTX4000 with 8 GB dedicated GDDR6 video memory
NVIDIA Quadro RTX5000 with 16 GB dedicated GDDR6 video memory
Feature
Display options
Non-touch
HP DreamColor Display, 39.62 cm (17.3 in) diagonal UHD anti-glare WLED-backlit, 400 nits, 100%
AdobeRGB with 10-bit color (3840 x 2160)
39.62 cm (17.3 in) diagonal FHD eDP anti-glare WLED-backlit, 300 nits with Ambient Light Sensor, 72% sRGB (1920 x 1080)
Touch
39.62 cm (17.3 in) diagonal UHD eDP with PSR, anti-glare, WLED-backlit, Corning Gorilla Glass 5 touch, 400 nits, 95%
sRGB with ambient light sensor (3840 x 2160)
note: |
Multi-display support
With HP Thunderbolt Dock G2
HP Thunderbolt Dock G2 has a Thunderbolt 3 port, a VGA, two DisplayPort 1.3, and a USB-C port. When used together with the HP ZBook 17 configuration with hybrid graphics, a maximum of five independent displays are supported.
These five displays are the internal panel,external display connected to the system’s HDMI port, and the three external displays connected to HP Thunderbolt Dock G2,Thunderbolt 3, VGA, or DisplayPort ports.
with Intel integrated graphics, a maximum of three independent displays are supported.
Any
3-display combination of the system panel, system ports, and ZBook Dock ports can be used.
Without HP Thunderbolt Dock G2
HP ZBook 17 configuration with hybrid graphics, supports a maximum
of four independent displays.
Internal panel, three external displays
connected to the Mini DisplayPort 1.3 or HDMI, and
two Thunderbolt 3 ports.
HP ZBook 17 configuration with Intel
integrated graphics supports up to a maximum of three independent displays. Any
three-display combination of the system panel: Mini DisplayPort or HDMI and two Thunderbolt 3.
note:Resolutions are dependent upon monitor capability and resolution and color depth settings.
Feature
Optical disc drive
Blu-ray R/RE DVD +/-RW SuperMulti DL Drive/M.2 SATA storage module Carrier
M.2 SATA SED SSD
512 GB M.2 SATA FIPS 140-2 Solid State Drive
M.2 PCIe (NVMe) SSD TLC
256 GB M.2 PCIe NVMe TLC Solid State Drive
512 GB M.2 PCIe NVMe TLC Solid State Drive
1 TB M.2 PCIe NVMe TLC Solid State Drive
2 TB M.2 PCIe NVMe TLC Solid State Drive
512 GB M.2 PCIe NVMe TLC Self-Encrypting Drive (SED) Solid State Drive
6.35 cm (2.5 in) Storage bay drives
500 GB SATA (7200 rpm) Hard Disk Drive
1 TB SATA (7200 rpm) Hard Disk Drive
2 TB SATA (5400 rpm) Hard Disk Drive
500 GB (7200 rpm) SATA FIPS 140-2 (7200 rpm) Hard Disk Drive
256 GB SATA TLC Solid State Drive
1 TB SATA TLC Solid State Drive
Cache Memory
16 GB PCIe NVMe Intel Optane Memory for storage acceleration
note: |
Drive controllers
6.35 cm (2.5 in) Storage bays and M.2 storage bay (SATA)
SATA-3 or SATA-2 for HDD
SATA-3 for SSD
HP Z Turbo drive
PCIe Gen 3x4 NVMe SSD
note:For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB is reserved for system recovery software.
Specification
Standard
(4) DDR4 SODIMM slots supporting dual-channel memory
Slots 3 and 4 are customer accessible or upgradeable
4 GB, 8 GB, and 16 GB SODIMMs (for Intel Core)
8 GB and 16 GB ECC SODIMMs (for Intel Xeon)
note: |
Maximum
128 GB DDR4-2667 non-ECC SDRAM
64 GB DDR4-2667 ECC SDRAM
note: |
note:Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory channels.Maximum memory capacities assume Windows 64-bit operating systems. With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements.
Ports
Left side
(1) RJ-45/Ethernet
(2) USB 3.1 Gen 1
(1) USB 3.1 Gen 1 (charging)
(1) Security lock slot (sold separately)
Right side
(2) USB Type-C 3 (Thunderbolt 3, pass through support DisplayPort 1.4, USB 3.1 Gen 2, with BC 1.2)
(1) HDMI 2.0b (HDMI port-cable not included; HDMI 2.0b with discrete, 1.4 with UMA)
(1) Stereo microphone in/headphone-out combo jack
(1) Mini DisplayPort 1.4 (Mini DP 1.4 with discrete, 1.2 with UMA)
(1) Power connector
Slots
(1) Smart card reader
(1) SD media card reader
Bays
(1) Optical disk drive bay
Feature
Audio
Audio by Bang & Olufsen
Dual stereo speakers
HP World Facing Microphone supporting HP Noise Reduction software
Digital dual-microphone array (when equipped with optional
webcam and optional world facing microphone)
Function keys for volume mute, up, and down
HP Clear
Sound Amp
Camera (optional)
1080p FHD webcam with IR camera (near infrared imaging)
720p HD webcam
Face authentication with Microsoft Hello certification
note: |
Feature
Keyboard
HP Collaboration Keyboard
Full-size, spill-resistant, backlit, with drain and DuraKeys
Spill resistant
Pointing devices
Dual pointstick
ClickPad (glass surface) with multi-touch gesture support
Taps enabled by default
Microsoft Precision Touchpad Default Gestures support
Feature
LAN
Integrated Intel I219-LM GbE, vPro
Integrated Intel I219-V GbE, non-vPro
note: |
Wireless
Intel Dual Band Wi-Fi 6 AX200 (2x2) and Bluetooth 5 combo, vPro
Intel Dual Band Wi-Fi 6 AX200 (2x2) and Bluetooth 5 combo, non-vPro
note: |
Wireless WAN (optional)
Intel XMM 7360 LTE-Advanced
note: |
Near Field Communication (optional)
Yes
Specification
BIOS
HP BIOSphere Gen5 (requires Intel 8th generation processors)
HP Sure Start Gen5 (requires Intel 8th generation processors)
HP Secure Erase (for the methods outlined in the National Institute of Standards and Technology Special
Publication 800-88)
Master Boot Record Security
Power On Authentication
Pre-boot Authentication
HP Sure Click (available on select platforms only as a web download from the HP Support website; preinstalled on select platforms, and supports Microsoft Internet Explorer and Chromium)
Absolute Persistence Module
note: |
HP Value add software
HP Hotkey Support
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP Performance Advisor
HP Remote Graphics Software (requires a Windows, Linux, or Mac OS X 10.10 and newer operating system and network
access)
HP Password Manager (requires Windows)
Microsoft products
Buy Office (sold separately)
Bing Search for IE11
Skype for Business Certified
Client Security software
HP Client Security Suite Gen5 (requires Windows)
HP Security Manager (including Credential Manager and Password Manager)
HP Fingerprint Sensor
Microsoft Defender
Security
Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
note: |
Other standard security features
Power-on password (via BIOS)
Removable media write/boot
control
SATA port disablement (via BIOS)
Serial enable/disable (via BIOS)
IR camera with Windows Hello
Support for Intel AT
HP Sure Recovery (requires an open, wired
network connection)
Optional security features
HP Fingerprint Sensor (optional)
IR Camera with Windows Hello
note:HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power supply
HP 200 W Slim Smart external AC power adapter
Primary battery
HP Long Life 6-cell, 95.6 Wh Li-ion polymer
Dimensions (W x D x H)
41.6 x 28.8 x 3.35 cm (16.4 x 11.35 x 1.3 in)
Starting at 3.2 kg (7.0 lb)
note: |
Feature
Certifications
US ENERGY STAR 7.1
Low halogen
note: IT ECO declaration
EPEAT 2019 registered where applicable (registration varies by country/region)
Stand-alone power
requirements (AC power)
Nominal operating
voltage
19.5 V DC
Maximum operating power
UMA < 200 W
Temperature
Operating
0° to 35° C (32° to 95° F)
Non-operating
-40° to 60° C (-40° to 140° F)
Relative humidity
Operating
10% to 90% (non-condensing)
Non-operating
5% to 95%
38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-15 to 3,048 m (-50 to 10,000 ft)
Non-operating
15 to 12,192 m (-50 to 15,000 ft)
