6EP07EA
HP Pavilion x360 - 15-cr0002nk
Intel® Core™ i5-8250U (1.6 GHz base frequency, up to 3.4 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
1 TB 5400 rpm SATA
39.6 cm (15.6") diagonal HD SVA micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 768)
Realtek RTL8821CE 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (5 Gb/s signaling rate); 2 USB 3.1 Gen 1 (Data Transfer Only, 5 Gb/s signaling rate); 1 HDMI; 1 headphone/microphone combo
2.08 kg
65 W AC power adapter
3-cell, 48 Wh Li-ion
Battery life mixed usage
Up to 12 hours and 15 minutes
Video Playback Battery life
Up to 10 hours and 45 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
