Figure : HP ZBook 15 G5 Mobile Workstation
Feature
Preinstalled
Windows 10 Pro for Workstations 64
Windows 10 Pro 64
note: FreeDOS 1.2
Supported
Windows 10 Enterprise 64
Red Hat Enterprise Linux (RHEL) 7
Ubuntu Linux 16.04
Intel Core i5-8300H
2.3 GHz base frequency (up to 4.0 GHz maximum Turbo Boost frequency)
2666 MHz, 8 MB cache, and 4 Cores
45 W
Intel UHD Graphics 630
note: |
Intel Core i5-8400H
2.5 GHz base frequency (up to 4.2 GHz maximum Turbo Boost frequency)
Intel vPro technology
45 W
note: |
Intel Core i7-8750H
2.2 GHz base frequency (up to 4.1 GHz maximum Turbo Boost frequency)
2666 MHz, 9 MB cache, and 6 Cores
45 W
note: |
Intel Core i7-8850H
2.6 GHz base frequency (up to 4.3 GHz maximum Turbo Boost frequency)
45 W
note: |
Intel Xeon E-2176M
2.7 GHz base frequency (up to 4.4 GHz maximum Turbo Boost frequency)
2666 MHz, 12 MB cache, and 6 Cores
45 W
Intel UHD Graphics P630
Intel Xeon E-2186M
2.9 GHz base frequency (up to 4.8 GHz maximum Turbo Boost frequency)
45 W
Intel Core i5/Core i7 and Xeon with vPro technology capable (optional)
Intel Virtualization Technology (Intel VT)
Intel Active
Management Technology (iAMT)
note: |
Mobile Intel CM246
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.Processor numbers differentiate features within each processor family, not across different processor families.Intel Turbo Boost is based on maximum GHz for a single core.
Feature
Integrated
Intel UHD graphics 630 (configurable as a standalone graphics option)
Intel UHD graphics P630 (only used when
NVIDIA Optimus Technology is enabled)
note: |
Discrete
AMD RadeonPro WX 4150
With 4 GB dedicated GDDR5 video memory
Microsoft DirectX 12 (Shader Model 5.0) and OpenGL 4.4 capable
NVIDIA Quadro P1000
NVIDIA Quadro P2000
note: |
Feature
Internal
39.62 cm (15.6 in) diagonal FHD IPS eDP, LED backlit, anti-glare (1920 x 1080)
39.62 cm (15.6 in) diagonal FHD IPS eDP with Panel Self Refresh (PSR), LED backlit, anti-glare, 400 nits with ambient light sensor (1920 x 1080)
HP Sure View Display 39.62 cm (15.6 in) diagonal FHD IPS eDP with Panel Self Refresh (PSR), LED backlit, 650 nits touch-screen with Corning Gorilla Glass 4 (1920 x 1080)
39.62 cm (15.6 in) diagonal FHD IPS eDP with Panel Self Refresh (PSR), LED backlit, anti-glare, 400 nits with ambient light sensor (3840 x 2160)
HP Sure View Display 39.62 cm (15.6 in) diagonal FHD IPS eDP with Panel Self Refresh (PSR), LED backlit, 650 nits touch-screen with Corning Gorilla Glass 4 (3840 x 2160)
note: |
Multi-display support
With HP Thunderbolt Dock G2
HP ZBook 15 with hybrid graphics supports up to a maximum of six independent
displays:
Internal panel, one external display connected to the system VGA port and four external displays connected to the
ZBook dock Thunderbolt 3, VGA, and two DP ports
HP ZBook 15 with Intel integrated graphics supports up to a maximum of three independent
displays:
Any three display combination of the system
panel, system ports, and ZBook Dock ports
Without HP Thunderbolt Dock G2
HP ZBook 15 with hybrid graphics supports up to a maximum of four independent
displays:
Internal panel plus three external displays connected to HDMI
2.0, Thunderbolt 3, Thunderbolt 3
HP ZBook 15 configuration with Intel integrated graphics supports up to a maximum of three independent displays:
Any three-display combination of HDMI, Thunderbolt 3, Thunderbolt 3
Feature
(1)
SATA 6.35 cm (2.5 in) Storage bay drives
2 TB 5400 rpm SATA
2 TB SATA SSHD (Hybrid Drive) (8 GB cache)
1 TB SATA SSHD (Hybrid Drive) (8 GB cache)
1 TB 7200 rpm SATA
1 TB SATA SSD
500 GB 7200 rpm SATA
500 GB SATA SSHD (Hybrid Drive) (8 GB cache)
500 GB 7200 rpm SATA SED (Self Encrypting Drive)
500 GB 5400 rpm SATA FIPS 140-2 SED Drive
256 GB SATA SSD
(2) M.2 SATA SED Solid State Drives (SSD)
256 GB SATA Self Encrypting Drive (SED)
512 GB SATA Self Encrypting Drive (SED)
16 GB Intel Optane cache (must be configured with HDD)
HP Z Turbo Drive (NVMe PCIe SSD)
256 GB PCIe (NVMe) TLC Solid State Drive
512 GB PCIe (NVMe) MLC Solid State Drive
1 TB PCIe (NVMe) MLC Solid State Drive
2 TB PCIe (NVMe) MLC Solid State Drive
512 GB PCIe (NVMe) TLC Opal 2 Solid State Drive
256 GB PCIe (NVMe) MLC Solid State Drive
HP 3D DriveGuard (Windows only)
Mounted directly to the notebook frame
Hard drive controllers
2.5 in storage bays and M.2 storage bay (SATA)
SATA-3 for HDD and SATA-3 for SSD
HP Z Turbo Drive
PCIe NVMe SSD
RAID
0, 1 supported only on SATA drives
note:For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 35 GB is reserved for system recovery software.
Specification
Standard
64 GB DDR4 ECC or non-ECC SDRAM (transfer rates up to 2667 MT/s)
note: (4) SODIMM slots supporting dual-channel memory
note: 4 GB, 8 GB, and 16 GB SODIMMs (for Intel Core processors)
8 GB and 16 GB ECC SODIMMs (for Intel Xeon processors)
note: |
Maximum
Up to 64 GB
Optional 16 GB SODIMMs in 4 slots
note:Maximum memory capacities assume Windows 64-bit operating systems. With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements.Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Ports
Left side
(1) RJ-45/Ethernet
(1) USB 3.0 (charging)
(1) USB 3.0
(1) Security lock slot
Right side
(1) HDMI 2.0
(2) Thunderbolt 3 (supporting DisplayPort 1.3, USB 3.1 Gen 2, PCIe Gen 3 devices)
(1) Stereo microphone-in/headphone-out combo jack
(1) Power connector
(2) USB 3.0
Digital media slots
(1) SD UHS-II Flash media slot
Supports next generation SD (Secure Digital), backward compatible to SDHC and SDXC
(1) Integrated Smart Card reader
Compatible with ISO 7816 compliant smart cards PC/SC interface support
Feature
Audio
Audio by Bang & Olufsen
Dual stereo speakers
Dual array digital microphone
Optional world facing microphone
Functions keys for volume up and down
Combo microphone/headphone jack
HP Noise Cancellation software, HP Clear Sound Amp and Skype for Business Certification
Optional HP Privacy Camera 720p HD webcam
Face authentication with Windows Hello
HD format (widescreen)
Supports videoconferencing and still image capture
High quality fixed focus lens
Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30fps
M-JPEG compression supports higher frame rates for video capture and videoconferencing
Improved low light sensitivity
Improved dynamic range
Feature
Keyboard
HP Premium Collaboration Keyboard
Full-size and spill-resistant backlight enabled
HP Durakey
Pointing devices
Touchpad with On/Off button
Two-way scroll
Gestures
Three pick buttons
Point stick with three additional point stick buttons
Image sensor touchpad for enhanced performance and improved precision on scroll and gesture
Function keys
F1 – Display switching
F2 – HP Sure View (if configured)
F3 - Brightness down
F4 – Brightness up
F5 – Speaker mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Keyboard backlight
F10 – NumLock
F11 – Wireless on/off
F12 – Calendar
F13 – Share screen
F14 – Call
F15 – End Call
Feature
Communications
Integrated Intel I219-LM Gigabit Network Connection (vPro configurations)
note: |
Broadband
Wireless (WWAN)
Requires a Windows operating system (not available in all countries/regions)
Factory
configurable only
Integrated Bluetooth
Combined with the supported
wireless LAN option
Factory configurable only
802.11 Wireless LAN
Intel Dual Band Wireless-AC 9560 802.11a/b/g/n/ac (2x2) WiFi with Bluetooth 4.2 Combo Adapter (vPro)
Intel Dual Band Wireless-AC 9560 802.11a/b/g/n/ac (2x2) WiFi with Bluetooth 4.2 Combo Adapter (non-vPro)
note: |
Wireless WAN - Mobile Broadband options
Intel XMMTM 7360 LTE-Advanced
HP It4132, LTE/HSPA+ 4G Mobile Broadband Module (optional)
note: |
Near Field Communication
NFC Mirage WNC XRAV-1 (NXP NPC300 I2C)
note: |
note:Secure, integrated wireless LAN and wireless WAN options supports the latest industry standards.
Specification
BIOS
HP BIOSphere Gen4
HP Sure Start with Gen4
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
HP LAN-WLAN Protection
Multimedia
Cyberlink Power MediaPlayer CMIT
Communication/connectivity
HP Mobile Connect Pro
note: Native Miracast Support
HP MAC Address Manager (select models only)
HP Host Based Mac Address
HP Wireless Wakeup (select models only)
HP SureConnect
HP Value Add Software
HP 3D DriveGuard 6 (requires Windows)
HP ePrint Driver with JetAdvantage2
HP Hotkey Support
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation Software
HP Performance Advisor
HP Remote Graphics Software
HP Velocity
Microsoft Products
Buy Office
Bing Search
Skype (not available in China)
Manageability
HP Driver packs (available for download)
HP SoftPaq Download Manager (SDM)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Management Integration Kit for Microsoft SCCM (available for download)
HP Image Assistant (available for download)
LANDESK Management (subscription required)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Client Security software
Microsoft Defender
HP WorkWise app (available as a free download on the App Store and Google Play)
HP Client Security Suite Gen3 (requires Windows and Intel 7th generation processors)
HP Security Manager (including Credential Manager and Password Manager)
HP Fingerprint Sensor (optional)
IR Camera with Windows Hello
Device Access Manager
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
HP Fingerprint Reader
For more information about security software and features, go to the HP Client Security Software Suite webpage.
Workstation ISV Certifications
Go to the Workstation ISV Certifications webpage to see current certifications
Available for download from HP Remote Graphics Software webpage
Enables optimal configuration
Available for download from HP Performance Advisor webpage
Other standard security features
One-Step Logon
Security lock slot
Support for Intel AT
HP Sure Run
HP Sure Recovery
HP Sure Click
Optional security features
Absolute Data Protect1
GPS Tracking - Subscription based security solution (requires HP Mobile Broadband Module)
note:1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.2Requires an Internet connection to HP web-enabled printer and HP ePrint account registration. Requires optional broadband module. Broadband use requires separately purchased service contract. Check with service provider for coverage and availability in your area. Separately purchased data plans or usage fees might apply. Print times and connection speeds might vary.3HP Touchpoint Manager requires purchase of a subscription and supports Android, iOS and Windows 7 or higher operating systems and PCs, notebooks, tablets and smartphones from various manufacturers. Not available in all countries/regions.
note:HP Cloud Recovery download tool (Cloud Recovery Client) is available under Software and Drivers section on the support page.
Power supply
HP 150W Slim Smart AC adapter
Primary battery
HP Long Life 4-cell Polymer battery (90 WHr)
note: |
Power conservation
NVIDIA Optimus or AMD Enduro Technology
Hibernation
Standby
ACPI compliance
Dimensions (W x D x H)
375.9 x 264.16 x 25.4 mm (14.8 in x 10.4 in x 1.0 in)
note: |
2.6 kg (5.73 lb)
note: |
Feature
Certifications
US ENERGY STAR (select models only)
note: IT ECO declaration
EPEAT Gold registered where applicable (registration varies by country/region)
UL
CSA
FCC compliance
Low Halogen
note: ICES (planned)
Australia/NZ A-Tick compliance (planned)
CCC (planned)
Japan VCCI compliance (planned)
KC (planned)
BSMI (planned)
CE marking compliance (planned)
note: |
Stand-alone power
requirements (AC power)
Nominal operating
voltage
19.5 V DC
Average operating power DreamColor
25 W (Windows 10 64-bit)
Average operating power without DreamColor
16.8 W (Windows 10 64-bit)
Maximum operating power
< 150 W
Temperature
Operating
0° to 35° C (32° to 95° F)
Non-operating
-20° to 35° C (-4° to 95° F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7° C (101.6° F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 15,000 ft)
