1ZC86EA
HP Pavilion x360 - 14-ba017ur
Intel® Core™ i3-7100U (2.4 GHz, 3 MB cache, 2 cores)
Flash cache
8 GB
6 GB DDR4-2133 SDRAM (1 x 2 GB, 1 x 4 GB)
Video graphics
NVIDIA® GeForce® 940MX (2 GB GDDR5 dedicated)
500 GB 5400 rpm SATA SSHD
35.6 cm (14") diagonal FHD IPS WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style keyboard
Pointing device
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI; 1 headphone/microphone combo
33.48 x 22.69 x 1.99 cm
1.72 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
B&O PLAY; HP Audio Boost; Dual speakers
