HP Officejet Enterprise Color X555 - Order parts, accessories, and supplies
Ordering
Order supplies and paper
Order genuine HP parts or accessories
Order through service or support providers
Contact an HP-authorized service or support provider.
Order using the HP Embedded Web Server (EWS)
To access, in a supported Web browser on your computer, enter the product IP address or host name in the address/URL field. The EWS contains a link to the HP SureSupply Web site, which provides options for purchasing Original HP supplies.
Parts and supplies
The following parts are available for the product.
Item
Part number
Cartridge number
Ink cartridges
D8J10A
HP 980A
Standard-capacity black ink cartridge with HP Officejet pigment ink
D8J07A
HP 980A
Standard-capacity cyan ink cartridge with HP Officejet pigment ink
D8J09A
HP 980A
Standard-capacity yellow ink cartridge with HP Officejet pigment ink
D8J08A
HP 980A
Standard-capacity magenta ink cartridge with HP Officejet pigment ink
Ink collection unit
B5L09A
HP Officejet Enterprise ink collection unit and duplex module
For information about the yield for the cartridges, see www.hp.com/go/pageyield. Actual yield depends on specific use.
Accessories
The following accessories are available for the product.
Item
Part number
Paper-handling accessory
B5L07A
HP Officejet Enterprise 500-sheet paper tray (optional Tray 3)1
Product cabinet and stand
B5L08A
HP Officejet Enterprise printer cabinet and stand
Network accessory
J8029A
HP NFC/Wireless Direct Accessory
USB cable
8121-0868
2-meter A-to-B cable
1Optional Tray 3 is available for the X555dn model only. You cannot add a second 500-sheet tray to the X555xh model.
