You can load different media in the trays and then request media by type or size by using the control panel.
note:The ALTERNATIVE LETTERHEAD MODE setting affects the way you load letterhead or preprinted paper. This setting is turned off by default. For more information, see System setup menu.
Paper type
Image orientation
Duplex mode
How to load paper
ALTERNATIVE LETTERHEAD MODE = Off
How to load paper
ALTERNATIVE LETTERHEAD MODE = On
Preprinted or letterhead
Portrait
1-sided printing
Face down
Top edge leading into the product
Figure : Paper orientation
Face up
Bottom edge leading into the product
2-sided printing
Face up
Face up
Landscape
1-sided printing
Face down
Top edge toward the back of the product
Face up
2-sided printing
Face up
Face up
Prepunched
Portrait or landscape
1- or 2-sided printing
Holes toward the back of the product
Not applicable
Envelopes
Long edge of the envelope feeding into the product
1-sided printing
Face down
Not applicable
Short edge of the envelope feeding into the product
1-sided printing
Face down
Not applicable
Paper type
Image orientation
Duplex mode
How to load paper
How to load paper
Portrait
1-sided printing
Face up
Top edge at the right side of the tray
Face down
Top edge at the left side of the tray
2-sided printing
Face down
Face down
Landscape
1-sided printing
Face up
Face down
2-sided printing
Face down
Face down
Prepunched
Not applicable
note:To see an animation of this procedure go to this Web site: www.hp.com/go/cljcp3525-load-tray1.
caution:To avoid jams, never add or remove paper from Tray 1 during printing.
Address type
Left margin
Top margin
Return
15 mm
15 mm
Destination
102 mm
51 mm
caution:Do not print envelopes, labels, postcards, or unsupported sizes of paper from the Tray 2. Print these types of paper only from Tray 1.
note:To see an animation of this procedure go to this Web site: www.hp.com/go/cljcp3525-load-tray2.
note:Do not open the tray while it is in use.
note:To prevent jams, do not overfill the tray. Be sure the top of the stack is below the tray full indicator.
note:If the tray is not adjusted correctly, an error message might appear during printing or the paper might jam.
caution:Do not print envelopes or unsupported sizes of paper from Tray 3. Print these types of paper only from Tray 1.
note:To see an animation of this procedure go to this Web site: www.hp.com/go/cljcp3525-load-tray3.
note:See the label in the paper tray, or the following illustration, to determine the X and Y dimensions.
note:To see an animation of this procedure go to this Web site: www.hp.com/go/cljcp3525-load-tray3-4x6.
