Your computer features top-rated components. This chapter provides details about your components, where they are located, and how they work.
Component
(1)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
warning: note: |
(2)
USB SuperSpeed port
Connects a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
(3)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High Definition Multimedia Interface (HDMI) device.
(4)
RJ-45 (network) jack/status lights
Connects a network cable.
(5)
USB Type-C power connector port, SuperSpeed port, and DisplayPort connector
Connects an AC adapter that has a USB Type-C connector, supplying power to the computer and, if needed, charging the computer battery.
– and –
Connects a USB device that has a Type-C connector, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
– and –
Connects a display device that has a USB Type-C connector, providing DisplayPort output.
note: |
(6)
Battery light
When AC power is connected:
When AC power is disconnected (battery not charging):
(7)
Power connector
Connects an AC adapter.
Component
(1)
Security cable slot
Attaches an optional security cable to the computer.
note: |
(2)
USB powered port
Connects and supplies power to a USB device, such as a cell phone, camera, activity tracker, optical drive, or smartwatch, and provides data transfer.
(3)
Vent
Enables airflow to cool internal components.
note: |
(4)
Memory card reader
Reads optional memory cards that store, manage, share, or access information.
To insert a card:
To remove a card:
(5)
Drive light
note:Refer to the illustration that most closely matches your computer.
Component
(1)
WWAN antennas* (select products only)
Send and receive wireless signals to communicate with wireless wide area networks (WWANs).
(2)
IR camera light (select products only)
On: The IR camera is in use.
(3)
Internal microphones (1 or 2 depending on model)
Record sound.
(4)
Camera(s) (select products only)
Allow(s) you to video chat, record video, and record still images. Some cameras also allow a facial recognition logon to Windows, instead of a password logon.
note: |
(5)
HD camera light (select products only)
On: The HD camera is in use.
(6)
WLAN antennas* (select products only)
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
To access this guide:
Component
(1)
(2)
Record sound.
(3)
note: |
(4)
(5)
Component
(1)
TouchPad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(2)
Left TouchPad button
Functions like the left button on an external mouse.
(3)
Right TouchPad button
Functions like the right button on an external mouse.
Component
(1)
Power light
(2)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(3)
Mute light
(4)
Microphone mute light
(5)
Wireless light
On: An integrated wireless device, such as a wireless local area network (WLAN) device and/or a Bluetooth® device, is on.
note: |
(6)
Num lk light
On: Num lock is on.
(7)
Fn lock light
On: The fn key is locked.
Component
(1)
Power button
caution: If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button for at least 5 seconds to turn off the computer.
To learn more about your power settings, see your power options.
(2)
Speakers (2)
Produce sound.
(3)
Fingerprint sensor (select products only)
Allows a fingerprint logon to Windows, instead of a password logon.
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes frequently used system functions when pressed in combination with another key. Such key combinations are called hot keys.
(3)
Windows key
Opens the Start menu.
note: |
(4)
Action keys
Execute frequently used system functions.
See Action keys.
(5)
num lk key
Alternates between the navigational and numeric functions on the integrated numeric keypad.
(6)
Integrated numeric keypad
A separate keypad to the right of the alphabet keyboard. When num lk is pressed, the integrated keypad can be used like an external numeric keypad.
note: |
Icon
Decreases the screen brightness incrementally as long as you hold down the key.
Increases the screen brightness incrementally as long as you hold down the key.
Turns the keyboard backlight off or on.
note: |
Plays the previous track of an audio CD or the previous section of a DVD or a Blu-ray Disc (BD).
Starts, pauses, or resumes playback of an audio CD, a DVD, or a BD.
Plays the next track of an audio CD or the next section of a DVD or a BD.
Stops audio or video playback of a CD, a DVD, or a BD.
Decreases speaker volume incrementally while you hold down the key.
Increases speaker volume incrementally while you hold down the key.
Mutes the microphone.
Mutes or restores speaker sound.
Turns the wireless feature on or off.
note: |
Turns the TouchPad and TouchPad light on and off.
Switches the screen image among display devices connected to the system. For example, if a monitor is connected to the computer, repeatedly pressing the key alternates the screen image from computer display to monitor display to simultaneous display on both the computer and the monitor.
Initiates Sleep, which saves your information in system memory. The display and other system components turn off and power is conserved. To exit Sleep, briefly press the power button.
caution: |
Provides quick access to your Skype for Business calendar.
note: |
Turns the screen sharing function on or off.
note: |
note: |
note: |
note:The action key feature is enabled at the factory. You can disable this feature by pressing and holding the fn key and the left shift key. The fn lock light will turn on. After you have disabled the action key feature, you can still perform each function by pressing the fn key in combination with the appropriate action key.
Key
C
Turns on scroll lock.
E
Turns on the insert function.
R
Breaks the operation.
S
Sends a programing query.
W
Pauses the operation.
Component
Vent
note: |
note:Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
Component
(1)
HP product name
(2)
Product ID
(3)
Serial number
(4)
Warranty period
