Product Name
15-ae010ur
Product Number
N3X00EA
Intel Core i7-5500U with Intel HD Graphics 5500 (2.4 GHz, 4 MB cache, 2 cores)
Memory
16 GB DDR3L-1600 SDRAM (2 x 8 GB)
Video Graphics
NVIDIA GeForce GTX 950M (4 GB DDR3L dedicated)
Hard Drive
2 TB 5400 rpm SATA
Multimedia Drive
SuperMulti DVD burner
39.6 cm (15.6") diagonal QHD+ UWVA anti-glare WLED-backlit (3200 x 1800)
Network Card
Integrated 10/100/1000 Gigabit Ethernet LAN
Wireless Connectivity
802.11b/g/n (1x1) and Bluetooth 4.0 combo (Miracast compatible)
Sound
Bang & Olufsen with 4 speakers and 1 subwoofer
Keyboard
Full-size backlit keyboard with integrated numeric keypad
Pointing Device
External Ports
1 HDMI 1 headphone/microphone combo 4 USB 3.0 (1 HP USB Boost) 1 RJ-45 |
Dimensions
38.4 x 25.5 x 2.29 cm
2.37 kg
Power
90 W AC power adapter
3-cell, 55.5 Wh prismatic |
Camera
HP TrueVision HD Webcam (front-facing) with integrated dual array digital microphone
