3V7P2PA
HP Laptop 14s-dq2535TU
Intel® Core™ i5-1135G7 (up to 4.2 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
Intel® Integrated SoC
8 GB DDR4-2666 MHz RAM (2 x 4 GB)
Video graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, HD (1366 x 768), micro-edge, BrightView, 250 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
32.4 x 22.5 x 1.79 cm
1.46 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Audio
Dual speakers
