This chapter provides you with an overview of your computer's features.
Standard configuration features
To identify a typical computer configuration, read this section. Features vary depending on the model. For support assistance and to learn more about the hardware and software installed on your computer model, run the HP Support Assistant utility.
Front panel components
To identify the front panel components, use this illustration and table.
![Identifying front panel components](/wcc-assets/document/images/277/c06953121.jpg)
1
HP Sure View button (select products only)
2
Fingerprint sensor (select products only)
3
SD card reader (select products only)
4
OSD buttons (4)
5
Power button
Rear panel components
To identify the rear panel components, use this illustration and table.
![Identifying rear panel components](/wcc-assets/document/images/920/c06953124.jpg)
1
USB ports (2)
2
RJ-45 (network) connector
3
Power connector
4
DisplayPort™ connector
5
USB Type-C® connector
6
USB ports (2)
7
HDMI In
8
Security cable slot
주의: |
Top components
To identify the top components, use this illustration and table.
![Identifying top components](/wcc-assets/document/images/309/c06953132.jpg)
Top components
1
Noise-canceling microphones
2
Webcam light
3
Infrared (IR) camera lens
Side components
To identify the side components, use this illustration and table.
![Identifying side components](/wcc-assets/document/images/182/c06953133.jpg)
Side components
1
Audio-out headphone jack
2
USB port
3
USB Type-C port
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available when contacting customer service for assistance.
![Locating the serial number](/wcc-assets/document/images/952/c06953135.jpg)
