A "Paper mismatch" error displays on the printer control panel, or the product prints to a tray that you were not expecting.
I want to...
Follow these steps
The product then does this...
Set the product to automatically select the correct tray.
Queries the trays and selects the first one with the correct media size and type, starting with the default tray.
If Tray 1 contains media and its tray configuration is set to Any Size and Any Type, the product prints to this tray first.
Print from Tray 1.
Prints from Tray 1 until the tray is empty. It then queries the other trays and prints from the first one with the correct media size and type.
Send a job to the printer, which waits until media is loaded into Tray 1.
Displays a message prompting you to load the correct media into that tray. After you load the media, the product prints only after you touch OK.
Print to a specific tray only.
Prints the job to the selected tray if the media size and type match.
If they do not match, the control panel displays a message, prompting you to load media into that tray that matches the media size and type selected for the print job in the printer software.
After the correct media is loaded, the printer automatically updates the tray configuration settings of media size and type to match the print job and prints.
Print to a specific tray if the media size and type match; if they do not match, print to another tray.
If they do not match, the product queries the other trays and prints from the first one with the correct media size and type.
