Your computer features top-rated components. This chapter provides details about your components, where they are located, and how they work.
Component
(1)
Drive light
(2)
Memory card reader
Reads optional memory cards that enable you to store, manage, share, or access information.
To insert a card:
To remove a card:
(3)
USB Type-C port
Connects a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides data transfer.
bemærk: |
(4)
USB SuperSpeed port
Connects a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
(5)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High-Definition Multimedia Interface (HDMI) device.
(6)
AC adapter and battery light
(7)
Power connector
Connects an AC adapter.
Component
(1)
USB SuperSpeed port
(2)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
vigitig advarsel: bemærk: |
(3)
Vent
Enables airflow to cool internal components.
bemærk: |
(4)
Power button
advarsel: If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button down for at least 5 seconds to turn off the computer.
To learn more about your power settings, see your power options:
(5)
Power light
(6)
Security cable slot
Attaches an optional security cable to the computer.
bemærk: |
Component
(1)
Internal microphones
Record sound.
(2)
Camera
Allows you to video chat, record video, and record still images. Some cameras also allow a facial recognition logon to Windows, instead of a password logon.
bemærk: |
(3)
Camera light
On: The camera is in use.
(4)
WLAN antenna(s)*
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
bemærk: |
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
To access this guide:
Component
(1)
TouchPad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(2)
Left TouchPad button
Functions like the left button on an external mouse.
(3)
Right TouchPad button
Functions like the right button on an external mouse.
Component
(1)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(2)
Mute light
Component
(1)
Speakers
Produce sound.
(2)
Fingerprint reader (select products only)
Allows a fingerprint logon to Windows, instead of a password logon.
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes specific functions when pressed in combination with another key.
(3)
Windows key
Opens the Start menu.
bemærk: |
(4)
Action keys
Execute frequently used system functions.
bemærk: |
Component
Vent
bemærk: |
bemærk:Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
Component
(1)
Model number
(2)
Serial number
(3)
Part number
(4)
Warranty period
