An HP LaserJet Enterprise printer logs a 10.15.23 code in the Event Log whenever a fuser is removed from the printer. This is a warning code reported in the printer for a customer to install a fuser before printing.
bemærk:A customer will not be prevented from using the printer when a printer logs a code in the Event log. The Event log lists a history of printer events and errors helpful for diagnosis.
A fuser is a pair of heated rollers and is one of the primary components that requires replacement in any of the following conditions:
when a jam occurs in the fuser area.
when removing a fuser for printer maintenance.
