HP PageWide Pro 700 series - "Format Problem" error displays on front panel when trying to print from USB thumb drive
Issue Description
This issue may appear if there is a bad or corrupted thumb drive in the rear port of the printer and the user tries to print a file from a thumb drive in the front USB port. A “Format Problem” error message displays on the front panel.
Workaround/Solution
Remove any USB thumb drive that is plugged into the rear port.
Product Numbers
The following products can exhibit the symptoms listed above:
Product models:
  • HP PageWide Pro 750dw
  • HP PageWide Pro Managed 75050dw
  • HP PageWide Pro MFP 772 series
  • HP PageWide Pro MFP 777 series
  • HP PageWide Pro Managed MFP 77740z
  • HP PageWide Pro Managed MFP 77750z
  • HP PageWide Pro Managed MFP 77760z
  • HP PageWide Pro Managed MFP 77740zs
  • HP PageWide Pro Managed MFP 77750zs
  • HP PageWide Pro Managed MFP 77760zs
Product numbers:
  • Y3Z47A
  • A7W97
  • W1B31
  • Y3Z54
  • Y3Z59
  • W1B39
  • W1B37
  • W1B38
  • W1B40
  • W1B41
  • W1B42
  • Y3Z44
  • Y3Z46
Serial Numbers
This issue is not constrained to a specific range of serial numbers.
