Product Specifications for the HP ENVY Inspire 7220e All-in-One Printer (242P6B)
Product naming
Model name
242P6B
What's included and accessories
What's in the box
HP ENVY Inspire 7220e All-in-One Printer; HP 303 Setup Black Instant Ink Ready Cartridge; HP 303 Setup Tri-Color Instant Ink Ready Cartridge; Ink Caution flyer; Regulatory flyer; Setup guide; Reference guide; HP Advanced Glossy and Matte Photo Inbox pouch; Power cord [For ink volume and page yield information, visit http://hp.com/go/learnaboutsupplies]
Accessories
None
Connectivity
Ports
1 USB 2.0 client ; 1 Wi-Fi 802.11a/b/g/n/ac, dual band Wi-Fi 2.4/5Ghz, BLE (setup only)
Wireless capability
Yes, built-in self-healing dual band Wi-Fi 802.11a/b/g/n/ac
Copy
Copier settings
Number of Copies; Two-Sided; Lighter/Darker; ID Copy; Resize; Quality; Paper Size; Paper Type; Collate; Margin Shift; Crop; Copy Preview; Enhancements
Color copy capability
Yes
Maximum number of copies
Up to 50 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed, black (draft, A4)
Up to 22 cpm
Copy speed, black (draft, Letter)
Up to 22 cpm
Copy resolution
Up to 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.3 B(A)
Acoustic pressure emissions
52 dB(A)
Recommended operating humidity range
20 to 80% RH
Non-Operating Humidity Range
10 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 32.5°C
Recommended operating temperature range (Fahrenheit)
59 to 90°F
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140°F
Environmental specifications
45% post-consumer recycled plastic; Recyclable through HP Planet Partners; Net zero-deforestation prints with HP+
Memory
Memory
256 MB DDR3
Maximum Memory
256 MB DDR3
Memory card compatibility
Not supported
Mobile printing capability
Mobile printing services
Apple AirPrint; Mopria Print Service; Chrome OS; HP Smart app
Paper handling
Input capacity
Up to 125 sheets
Standard input capacity (cards)
Up to 40 cards
Standard input capacity (envelopes)
Up to 5
Standard input capacity (secondary tray)
Up to 15 sheets
Output capacity
Up to 60 sheets
Media sizes supported (metric)
Main Tray: A4, A5, A6, B5(ISO), B5(JIS), 10 x 15 cm, 10 x 30 cm, 2L, Hagaki, Ofuku Hagaki, Envelope (A2, C5, C6, DL, #10, Chou #3); Photo tray: 10 x 15 cm, 13 x 13 cm, 13 x 18 cm
Media sizes supported (U.S. standard)
Main Tray: Letter, Executive, Statement (8.5 x 5.5 in), 4 x 6 in, 5 x 7 in, 8 x 10 in, 4 x 12 in, Envelope (#10, A2); Photo Tray: 5 x 5 in, 4 x 6 in, 5 x 7 in
Media sizes, custom (metric)
Main Tray: 97.79 x 215 to 127 x 309 mm; Photo Tray: No custom media sizes
Media sizes, custom (U.S. standard)
Main Tray: 3.85 x 8.5 to 5 x 12.2 in; Photo Tray: No custom media sizes
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Other Photo Inkjet Papers; Other Matte Inkjet Papers; Other Glossy Inkjet Papers, Plain Paper, Light/Recycled
Media weight supported (metric)
Tray 1: A4: 75 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP Photo Paper: up to 300 g/m²; Photo Tray: photo paper: up to 300 g/m²
Media weight supported (U.S. standard)
18 to 22 lb
Borderless printing
Yes (up to 8.5 x 11 in, 216 x 297 mm)
Paper handling - duplexer
Media sizes, duplex (U.S. standard)
Letter, Executive (all media lengths between 5.5 and 12.2")
Physical dimensions
Maximum dimensions (W x D x H, metric)
460 x 511 x 190.5 mm
Maximum dimensions (W x D x H, U.S. standard)
18.11 x 20.1 x 7.5 in
Weight (metric)
6.91 kg
Weight (U.S. standard)
15.23 lb
Power
Energy savings feature technology
HP Auto-Off Technology; Schedule On and Schedule Off
Internal universal power supply
Power supply
2 wire (Class 2) internal, dual mode AC/DC power supply. 100-240Vac, 50/60Hz, 0.7A input. 32V/12V (sleep), 469mA/166mA (sleep), 15W/2W (sleep) output. Not dual voltage, power supply varies by part number with # Option code identifier.
Power consumption
Up to 14 Watts (printing), 4.9W (ready), 1.05W (sleep), 0.05 Watts (manual off)
Print cartridges
Number of print cartridges
2 (1 each black, tri-color)
Replacement cartridges
HP 303 Black Original Ink Cartridge (~200 pages) T6N02A; HP 303 Tri-Color Original Ink Cartridge (~165 pages) T6N01A; HP 303XL Black Original Ink Cartridge (~600 pages) T6N04A; HP 303XL Tri-Color Original Ink Cartridge (~415 pages) T6N03A. Actual yield varies considerably based on content of printed pages and other factors. For details see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic
Print speed (black, draft, Letter)
Up to 22 ppm
Print speed (color, draft, Letter)
Up to 20 ppm
Print speed black (ISO)
Up to 15 ppm
Print speed color (ISO)
Up to 10 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi
Maximum print area (metric)
209.9 x 349.6 mm
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Printer smart software features
Orientation: Portrait/Landscape; Print on Both Sides: None/Flip on Long Edge/Flip on Short Edge; Page Order: Front to Back/Back to Front; Pages per Sheet: 1, 2, 4, 6, 9, 16; Quality Settings: Draft/Normal/Best; Printing Shortcuts; Print in Grayscale: Off/High Quality Grayscale/Black Ink Only; Pages per Sheet Layout: Right then Down/Down then Right/Left then Down/Down then Left; Print in Max DPI: No/Yes; HP Real Life Technologies: Off/On; Booklet: None/Booklet-Left Binding/Booklet-Right Binding; Pages to Print: Print All Pages/Print Odd Pages Only/Print Even Pages Only; Borderless Printing: Off/On; Page Borders: Off/On
Regulatory specifications
Safety
IEC 60950-1:2005 (2nd Edition) Am1:2009 + Am2:2013/EN 60950-1:2006 + A11:2009 + A1:2010 + A12:2011 + A2:2013; IEC62368-1:2014 (2nd Edition)/EN62368-1:2014+A11:2017; UL 62368-1: 2nd Edition; German GS; Russia EAC; China CCC; Taiwan BSMI
Electromagnetic compatibility
EN 55032:2012/AC:2013 Class B;ETSI EN 301 489-1 V2.2.3:2019-11;ETSI EN 301 489-17 V3.2.4:2020-09;EN 55032:2012/AC:2013 Class B;ETSI EN 301 489-1 V2.2.3:2019-11;ETSI EN 301 489-17 V3.2.4:2020-09;IEC 61000-4-2:2008;EN 55035:2017;ETSI EN 301 489-1 V2.2.3:2019-11;ETSI EN301 489-17 V3.2.4:2020-09;IEC 61000-4-3:2010;EN 55035:2017;ETSI EN 301 489-1 V2.2.3:2019-11;ETSI EN301 489-17 V3.2.4:2020-09;IEC 61000-4-8:2009;EN 55035:2017 ETSI EN 301 489-1 V2.2.3:2019-11;ETSI EN301 489-17 V3.2.4:2020-09;IEC 61000-4-11:2004 +A1:2017;EN 55035:2017;ETSI EN 301 489-1 V2.2.3:2019-11;ETSI EN301 489-17 V3.2.4:2020-09
Scan
Scanner advanced features
Supported using HP Smart App
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Scanning options (ADF)
No ADF
Maximum flatbed scan size (metric)
215.9 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.7 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Intel Pentium II, Celeron or 233 MHz or better processor; 2 GB available hard disk space; Internet connection; web browser
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
macOS High Sierra v10.13 (or later); 1.5 GB available space; Internet access
Recommended Macintosh system requirements
Compatible Network Operating Systems
Windows 11, Windows 10 (32-bit and 64 bit), Windows 7 SP1 (32-bit and 64 bit), macOS High Sierra v10.13 (or later); Chrome OS (post initial setup)
Operating system (supported note)
Windows 8 and 8.1 not supported
Manufacturer Warranty
Up to 2 years HP Warranty. 24-hour, 7 days a week Web support; Business hour phone support within warranty period. Two years consist of: (1) one year standard HP warranty; (2) one year extra HP warranty through HP+ activation at setup
