44W94EA
HP Pavilion x360 Convertible 14-dy0004nx
Intel® Core™ i7-1165G7 (up to 4.7 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 4 cores, 8 threads)
Intel® Integrated SoC
8 GB DDR4-3200 MHz RAM (2 x 4 GB)
Video graphics
Intel® Iris® Xᵉ Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), multitouch-enabled, IPS, edge-to-edge glass, micro-edge, 250 nits, 45% NTSC
Intel® Wi-Fi CERTIFIED 6™ AX201 (2x2) and Bluetooth® 5 combo (Supporting Gigabit data rate)
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 AC smart pin; 1 headphone/microphone combo
32.2 x 20.9 x 1.99 cm
1.56 kg
65 W Smart AC power adapter
3-cell, 43 Wh Li-ion polymer
Battery life mixed usage
Up to 8 hours and 30 minutes
Video Playback Battery life
Up to 12 hours and 30 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio
Audio by B&O; Dual speakers; HP Audio Boost
