Feature
Preinstalled (Windows)
Windows 10 Pro 64 (National Academic License)
note: Windows 10 Pro 64 (recommended by HP)
Windows 10 Enterprise 64 (Volume Licensing Agreement)
note: |
Preinstalled (other)
FreeDOS 1.2
note:In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Feature
Intel Core i7-1165G7 Processor
2.8 GHz Base frequency, up to 4.7 GHz with Intel Turbo Boost Technology
12 MB cache, 4 cores
Intel Core i5-1135G7 Processor
2.4 GHz Base frequency, up to 4.2 GHz with Intel Turbo Boost Technology
8 MB cache, 4 cores
Integrated with processor
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Feature
Standard
DDR4-PC4 SODIMMS
Supports dual-channel memory
System runs at 3200 MT/s
Configurations
64 GB DDR4-3200 SDRAM (2 x 32 GB)
32 GB DDR4-3200 SDRAM (2 x 16 GB)
16 GB DDR4-3200 SDRAM (1 x 16 GB)
16 GB DDR4-3200 SDRAM (2 x 8 GB)
8 GB DDR4-3200 SDRAM (1 x 8 GB)
8 GB DDR4-3200 SDRAM (2 x 4 GB)
4 GB DDR4-3200 SDRAM (1 x 4 GB)
Maximum
64 GB
note:Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Feature
Integrated
Intel Iris Xe Graphics
note: |
Supported
HD decode, DX12, HDMI 2.0b, and HDCP 2.3
Feature
Wireless LAN (WLAN)
Intel Wi-Fi 6 AX201 (2x2) and Bluetooth 5 combo, vPro
Intel Wi-Fi 6 AX201 (2x2) and Bluetooth 5 combo, non-vPro
note: |
WWAN
Intel XMM 7360 LTE-Advanced Cat 9
note: Qualcomm Snapdragon X55 5G Cat 20
note: |
NFC
HP Module with NXP NFC Controller NPC300 12C NCI (sold separately or as an optional feature)
Miracast
Yes
Feature
Non-touch display
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP, 250 nits, 45% NTSC (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP, 250 nits, 45% NTSC for HD Camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP, 250 nits, 45% NTSC for HD and IR Camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP, 250 nits, 45% NTSC for WWAN 4G (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP, 250 nits, 45% NTSC for HD Camera for WWAN 4G (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP, 250 nits, 45% NTSC for HD and IR Camera for WWAN 4G (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP, 250 nits, 45% NTSC for HD and IR Camera for WWAN 5G (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP and PSR, 400 nits, 100% sRGB, Low Power Ambient Light Sensor for HD and IR Camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP and PSR, 400 nits, 100% sRGB, Low Power Ambient Light Sensor for HD and IR Camera for WWAN 4G (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP and PSR, 400 nits, 100% sRGB, Low Power Ambient Light Sensor for HD and IR Camera for WWAN 5G (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP and PSR, 1000 nits, 100% sRGB with HP Sure View Reflect integrated privacy screen, Ambient Light Sensor for HD Camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP and PSR, 1000 nits, 100% sRGB with HP Sure View Reflect integrated privacy screen, Ambient Light Sensor for HD and IR Camera (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP and PSR, 1000 nits, 100% sRGB with HP Sure View Reflect integrated privacy screen, Ambient Light Sensor for HD Camera for WWAN 4G (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP and PSR, 1000 nits, 100% sRGB with HP Sure View Reflect integrated privacy screen, Ambient Light Sensor for HD and IR Camera for WWAN 4G (1920 x 1080)
33.78 cm (13.3 in) diagonal FHD bent, anti-glare UMA eDP and PSR, 1000 nits, 100% sRGB with HP Sure View Reflect integrated privacy screen, Ambient Light Sensor for HD and IR Camera for WWAN 5G (1920 x 1080)
note: |
Touch display
35.56 cm (14.0 in) diagonal FHD bent, anti-glare UMA eDP, 250 nits, 45% NTSC for HD and IR Camera Touch on Panel (1920 x
1080)
35.56 cm (14.0 in) diagonal FHD bent, anti-glare UMA eDP, 250 nits, 45% NTSC for HD and IR Camera for WWAN 4G Touch on
Panel (1920 x 1080)
HDMI 2.0
Supports resolutions up to 4K at 60 Hz (cable sold separately)
note:High-definition (HD) content is required to view high definition images.Resolutions are dependent upon monitor capability and resolution and color depth settings.
Feature
Primary M.2 Solid State Drive storage
128 GB PCIe Gen 3 x2 NVMe M.2 TLC SSD
256 GB PCIe Gen 3 x4 NVMe M.2 TLC SSD
512 GB PCIe Gen 3 x4 NVMe M.2 TLC SSD
1 TB PCIe Gen 3 x4 NVMe M.2 TLC SSD
2 TB PCIe Gen 3 x4 NVMe M.2 TLC SSD
256 GB PCIe NVMe Value M.2 SSD
512 GB PCIe NVMe Value M.2 SSD
512 GB PCIe Gen 3 x4 NVMe M.2 OPAL2 SED TLC SSD
256 GB PCIe Gen 3 x4 NVMe M.2 OPAL2 SED TLC SSD
512 GB PCIe Gen 3 x4 NVMe M.2 2280 QLC SSD with 32 GB Intel Optane Memory
note:For solid state drives or hard drives, GB = 1 billion bytes; TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Feature
Ports
(2) USB Thunderbolt 4 Type-C ports with USB4 support (SuperSpeed USB 20 Gbps is not available)
(2) USB 3.2 Gen 1 Type-A ports (1 Charging)
(1) Headphone/microphone combo jack
(1) AC power port
(1) HDMI 2.0 (cable sold separately)
(1) AC Power input port
Slots
(1) Nano SIM card slot (not accessible without WWAN)
note: (1) Smartcard reader (optional)
(1) Nano security lock slot (lock sold separately)
Feature
Audio
Audio by Bang & Olufsen
(2) Integrated stereo speakers
Integrated dual-array microphone
Camera (sold separately)
720p HD camera
720p HD and IR camera (sold separately and internet access required)
note: |
Sensors
Ambient light sensor (select models only)
Hall Sensor
Feature
HP Premium keyboard
Spill-resistant and backlight function
Optional backlight keyboard and DuraKeys
Pointing device
Clickpad with multi-touch gesture support
Taps enabled as default
Microsoft Precision Touchpad default gestures support
Function keys
Function keys
F1 – Display switching
F2 – Blank or Privacy (with LED)
F3 – Brightness down
F4 – Brightness up
F5 – Audio mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Blank or backlight toggle
F10 – Insert
F11 – Airplane Mode
F12 – HP Programmable Key
Print Screen
Power Button (with LED)
Hidden functions
Fn + R - Break
Fn + S - System Rq
Fn + C - Scroll Lock
Feature
BIOS
HP BIOSphere Gen6 (available on select platforms with 8th generation processors)
HP Sure Start Gen5 (available on select platforms with 8th generation processors)
BIOS Update via Network
Power On Authentication
Master Boot Record Security
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
Absolute Persistence Module
note: |
Communication/connectivity
HP Connection Optimizer
HP Value add software
HP Hotkey Support
HP Sure Recover Gen4 (requires internet connection and not for systems with multiple drives)
HP Pro Security Edition (select models)
HP Sure Click
HP Sure Sense
HP Sure Start Gen6
HP Sure Run Gen4
HP Sure Admin
HP Recovery Manager
HP Sure Sense (requires Windows)
HP Image Assistant
HP Device Access Manager
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP QuickDrop
HP Touchpoint Customizer
HP Power Manager
HP WorkWell
myHP
Tile App (for Windows 10)
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Client Management Script Library (available for download)
HP Management Integration Kit Gen4 (available for download)
note: |
Security
HP Client Security Manager Gen6 (requires Windows and available on select platforms)
HP Fingerprint Sensor (sold separately or as an optional feature)
Microsoft Defender (opt in and internet connection required for updates)
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Other standard security features
Setup password (via BIOS)
Support for chassis padlocks and cable lock devices
Feature
Power supply
Adapters
HP Smart 45 W External AC power adapter
HP Smart 45 W External AC power adapter; 2-prong (Japan only)
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
HP Smart 65 W USB Type-C adapter
Power cords
3-wire plug - 1 m (3.28 ft)
2-wire plug - 1 m (3.28 ft)
note: |
Primary battery
HP Long Life 3-cell, 56 Wh Li-ion
Support HP Fast Charge (up to 50% in 30 minutes with 65 W AC adapter)
note: |
Feature
Non-touch
Starting at 1.26 kg (2.78 lb)
Touch
Starting at 1.37 kg (3.02 lb)
note: |
Dimensions (W x D x H)
30.76 x 20.45 x 1.78 cm (12.11 x 8.05 x 0.7 in)
