Specification
Preinstalled
Windows 10 Pro 64 (National Academic only)
note: Windows 10 Pro 64
Windows 10 China Government Edition
note: FreeDOS 1.2
note:In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Specification
Intel Core i7-8565U processor
1.8 GHz base frequency, up to 4.6 GHz with Intel Turbo Boost
Technology
8 MB cache and 4 cores
Intel UHD Graphics 620
Intel Core i7+ 8565U processor
Technology
16 GB Intel Optane memory
Intel Core i5-8265U processor
1.6 GHz base frequency, up to 3.9 GHz with Intel Turbo Boost
Technology
6 MB cache and 4 cores
Intel Core i5+ 8265U processor
Technology
Intel Core i3-8145U processor
2.1 GHz base frequency, up to 3.9 GHz with Intel Turbo Boost
Technology
4 MB cache and 2 cores
Intel Celeron 4205U processor
2 MB L3 cache and 2 cores
Intel UHD Graphics 610
Intel Pentium 5405U processor
2.3 GHz base frequency
Integrated with processor
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Specification
Integrated
Intel UHD Graphics 620 (for Core i7/i5/i3)
Intel UHD Graphics 610 (for Celeron 4205U and Pentium 5405U)
note: |
Specification
Internal
Non-touch
33.8 cm (13.3 in) diagonal HD SVA eDP anti-glare LED-backlit Ultraslim, 220 cd/m2, 67% sRGB for two WLAN antennas (1366 x 768)
33.8 cm (13.3 in) diagonal HD SVA eDP anti-glare LED-backlit Ultraslim, 220 cd/m2, 67% sRGB for HD camera and two WLAN antennas (1366 x 768)
33.8 cm (13.3 in) diagonal HD SVA eDP anti-glare LED-backlit Ultraslim, 220 cd/m2, 67% sRGB for HD camera, WWAN and two
33.8 cm (13.3 in) diagonal HD SVA eDP anti-glare LED-backlit Ultraslim, 220 cd/m2, 67% sRGB for HD+IR camera and two WLAN antennas (1366 x 768)
33.8 cm (13.3 in) diagonal FHD UWVA eDP anti-glare LED-backlit slim, 220 cd/m2, 67% sRGB for HD camera and two WLAN antennas (1920 x 1080)
33.8 cm (13.3 in) diagonal FHD UWVA eDP anti-glare LED-backlit slim, 220 cd/m2, 67% sRGB for HD+IR camera and two WLAN antennas (1920 x 1080)
Touch
33.8 cm (13.3 in) diagonal HD SVA eDP LED-backlit Ultraslim touch screen, 220 cd/m2, 67% sRGB for HD camera and two WLAN
33.8 cm (13.3 in) diagonal FHD UWVA eDP LED-backlit slim touch screen, 220 cd/m2, 67% sRGB for HD camera and two WLAN
33.8 cm (13.3 in) diagonal FHD UWVA eDP LED-backlit slim touch screen, 220 cd/m2, 67% sRGB for HD camera, WWAN and two
note: |
Specification
Primary M.2 Solid State Drive storage
128 GB SATA-3 TLC SSD
256 GB PCIe Gen 3x4 NVMe Value TLC SSD
512 GB PCIe Gen 3x4 NVMe TLC SSD
512 GB PCIe NVMe M.2 Value SSD
Primary SATA Hard drives
500 GB 7200 RPM
1 TB 5400 RPM
note:For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Specification
Standard
DDDR4-PC4 SODIMMS
Supports dual-channel memory
(2) Dual-channel SODIMM slots (both slots are customer accessible/upgradable)
Runs at 2400 MT/s for Intel 8th generation processors
Configurations
32 GB DDR4-2400 SDRAM (16 GB x 2)
16 GB DDR4-2400 SDRAM (16 GB x 1)
16 GB DDR4-2400 SDRAM (8 GB x 2)
12 GB DDR4-2400 SDRAM (8 GB x 1 and 4 GB x 1)
8 GB DDR4-2400 SDRAM (8 GB x 1)
8 GB DDR4-2400 SDRAM (4 GB x 2)
4 GB DDR4-2400 SDRAM (4 GB x 1)
Maximum
32 GB
note:Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Specification
Ports
(1) USB 3.1 Type-C connector (Power Delivery, DisplayPort)
(1) USB 3.1 Gen 1
(1) USB 3.1 Gen 1 (Powered port)
(1) HDMI 1.4b
(1) RJ-45/Ethernet port
(1) Headphone/microphone combo jack
(1) AC power port
note: |
Slot
(1) SD Card reader
note: |
Specification
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 9560 802.11ac (2x2) WLAN and Bluetooth 5 Combo, non-vPro
Realtek 802.11ac (2x2) WLAN and Bluetooth 4.2 Combo
note: |
Wireless WAN (WWAN)
Intel XMM 7262 LTE-Advanced (Cat6)
Intel XMM 7360 LTE-Advanced (Cat9)
note: |
Ethernet
Realtek RTL8111HSH-CG 10/100/1000 GbE NIC
note: |
Specification
Audio
Integrated microphone (mono or dual-array)
(2) Integrated stereo speakers
Camera (optional)
720p HD HP and IR Camera
note: 720p HD HP Camera
note: |
Specification
HP Premium keyboard
Spill-resistant with optional backlit function
Pointing device
Clickpad with multi-touch gesture support
Function keys
Function keys
ESC – System information
F1 – Display switching
F2 – Blank
F3 – Brightness down
F4 – Brightness up
F5 – Audio mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Backlight toggle (for backlit keyboard)
F10 – Num lock
F11 – Wi-Fi toggle
F12 – Sleep
Hidden functions
Fn+R - Break
Fn+S - System Rq
Fn+C - Scroll Lock
Fn+E - Insert
Specification
BIOS
HP BIOSphere Gen4 (requires Intel 8th generation processors)
HP Sure Start Gen4 (requires Intel 8th generation processors)
BIOS Update via Network
Master Boot Record Security
Power On Authentication
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Absolute Persistence Module1
Pre-boot Authentication
HP Wireless Wakeup
Communication/connectivity
HP Native Miracast support
HP LAN-WLAN Protection
HP Connection Optimizer
HP Value add software
HP PhoneWise
HP Hotkey Support - CMIT
HP Recovery Manager
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP Host Based MAC Address Manager
Ivanti Management Suite (subscription required)
Microsoft products
Buy Office
Manageability
HP Driver packs (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Cloud Recovery
HP Management Integration Kit for Microsoft SCCM (available for download)
note: |
Client Security software
HP Security Manager (including Credential Manager and HP Password Manager, and HP Spare Key)
note: HP Fingerprint Sensor (sold separately or as an optional feature)
HP 3D DriveGuard
HP Device Access Manager
HP Sure Click (supports Microsoft Internet Explorer and Chromium)
Microsoft Defender (opt in and internet connection required for updates)
Security
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
HP Fingerprint Reader (sold separately or as an optional feature)
note: |
Other standard security features
SATA 0 and 1 port disablement (via BIOS)
RAID (optional and requires a second hard drive)
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
Integrated hood sensor
Support for chassis padlocks and cable lock devices
Security lock slot (lock sold separately)
note:1Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Specification
Power supply
Adapters
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
HP Smart 65 W USB Type-C adapter
HP Smart 45 W External AC power adapter
HP Smart 45 W USB Type-C adapter
Power cords
3-wire plug - 1 m (3.28 ft)
3-wire plug - 1.8 m (5.9 ft)
2-wire plug - 1 m (3.28 ft)
Duckhead power cord - 1 m (3.28 ft)
Duckhead power cord - 1.8 m (5.9 ft)
note: |
Primary battery
HP Long Life 3-cell, 45 Wh Li-ion
note: |
Specification
Starting at 1.49 kg (3.28 lb)
note: |
Dimensions (W x D x H)
30.86 x 23.09 x 1.80 cm (12.15 x 9.09 x 0.71 in)
