Figure : HP 280 G3, 290 G1 Microtower Business PC
![HP 280 G3, 290 G1 Microtower Business PCs](/wcc-assets/document/images/20/c05529272.jpg)
Specification
Intel Core i7-7700 processor (available in August)
65 W
Up to 4.2 GHz maximum Turbo Frequency (3.6 GHz base frequency)
8 MB SmartCache cache, 4 cores, 8 threads
Intel HD Graphics 630
Supports DDR4 memory up to 2400 MT/s data rate
Intel Core i7-6700 processor
65 W
Up to 4.0 GHz maximum Turbo Frequency (3.4 GHz base frequency)
8 MB cache, 4 cores, 8 threads
Intel HD Graphics 530
Supports DDR4 memory up to 2133 MT/s data rate
Intel Core i5-7500 processor
65 W
Up to 3.8 GHz maximum Turbo Frequency (3.4 GHz base frequency)
6 MB cache, 4 cores, 4 threads
Intel Core i5-6500 processor
65 W
Up to 3.6 GHz maximum Turbo Frequency (3.2 GHz base frequency)
Intel Core i3-7100 processor
51 W
3.9 GHz base frequency
3 MB cache, 2 cores, 4 threads
Intel Core i3-6100 processor
51 W
3.7 GHz base frequency
Intel Pentium G4560 processor
54 W
3.5 GHz base frequency
Intel HD Graphics 610
Intel Pentium G4400 processor
54 W
3.3 GHz base frequency
3 MB cache, 2 cores, 2 threads
Intel HD Graphics 510
Intel Celeron G3930 processor
51 W
2.9 GHz base frequency
2 MB cache, 2 cores, 2 threads
Intel Celeron G3900 processor
51 W
2.8 GHz base frequency
Intel H110
note:Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. 64-bit computing system required. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Specification
Integrated
Intel Integrated HD Graphics (varies by processor)
Discrete (optional for selected countries only)
NVIDIA GeForce GT 730 1 GB/2 GB PCIe x8 HDMI
AMD Radeon R5 420 card (for China only)
AMD Radeon R7 430 card (for China only)
Specification
DDR4-2400
Maximum: 32 GB
Number of slots: (2) DIMM (both slots are customer accessible/upgradeable)
Supports dual-channel memory
Up to 2400 MT/s
Configurations
4 GB DDR4-2400 DIMM (1 x 4 GB)
8 GB DDR4-2400 DIMM (1 x 8 GB)
16 GB DDR4-2400 DIMM (1 x 16 GB)
note:Addressing memory above 4 GB requires a 64-bit operating system. With Windows 32-bit operating systems, the amount of usable memory is dependent upon the configuration, therefore above 3 GB, all memory might not be available due to system resource requirements.Memory modules support data transfer rates up to 2400 MT/s; actual data rate is determined by the system configured processor. See processor specifications for supported memory data rate.
Specification
SATA Hard Disk Drive (HDD)
500 GB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
1 TB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
2 TB, 7.2 K rpm, SATA 6.0 Gb/s, 8.89 cm (3.5 in)
SATA Solid State Drive (SSD)
128 GB SATA 6.0 Gb/s 6.35 cm (2.5 in)
256 GB SATA 6.0 Gb/s 6.35 cm (2.5 in)
Optical disc drives
HP 9.5 mm (0.37 in) Desktop G3 Slim DVD-ROM
HP 9.5 mm (0.37 in) Desktop G3 Slim DVD Writer
note: |
Multi-format digital media card reader (optional)
HP 6-in-1 SD Media Card Reader
note: |
note:For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB of system disk is reserved for the system recovery software.
Specification
Keyboards (optional or add-on feature)
Universal USB Wired keyboard
HP PS/2 Business Slim keyboard (optional and not available in all countries/regions)
HP PS/2 keyboard (optional and not available in all countries/regions)
HP USB Antimicrobial keyboard (China only)
HP USB Business Slim keyboard
Mice (optional or add-on feature)
HP USB mouse (not available for India)
HP PS/2 mouse (optional and not available in all countries/regions)
HP USB Antimicrobial mouse (China only)
Specification
Ports
Front I/O ports
(2) USB 3.0
(1) Microphone/Headphone combo jack (CTIA)
Rear I/O ports
(4) USB 2.0
(2) USB 3.0
(1) RJ-45
(1) Audio Line-in
(1) Audio Line-out
(1) VGA
(1) HDMI
Internal I/O ports
(1) PCIe x16 (3.0)
(1) PCIe x1 (2.0)
(1) M.2 for WLAN
(1) PCI 2.3 (optional and not available in all countries/regions)
Optional and not available in all countries/regions
(1) Serial (RS-232)
(1) PS/2
Bays
(1) 8.89 cm (3.5 in) Hard Disc Drive (HDD)
(1) 8.89 cm (3.5 in)/6.35 cm (2.5 in) Hard Disc Drive (HDD) bay (no bracket required)
(1) 0.9 cm (0.35 in) Optical Disc Drive (ODD)
(1) SD Card reader (optional)
Specification
Type
Integrated Hi-Definition audio: Internal amplifier
Conexant CX20632 Audio Codec
Audio in/out ports
Line-out and line-in rear ports, 3.5 mm (0.14 in)
note: |
Internal speaker (standard)
Yes
2.0 W amplifier
Multi-streaming capable
Yes
note: |
Specification
Ethernet (RJ-45)
Integrated 10/100/1000M Gigabit Ethernet Controller - Realtek RTL8111HSH-CG GbE Ethernet
Supports Wake-on-LAN (WOL)
Wireless LAN (WLAN) (optional)
Intel 3168 802.11ac 2x2 Wi-Fi with Bluetooth M.2 Combo Card non-vPro (optional)
Realtek RTL8723DE 802.11b/g/n 1x1 M.2 PCIe (optional and available in August)
note: |
Specification
Preinstalled
Varies by country/region
Multimedia
Cyberlink Power Media Player (select platforms only)
Cyberlink Power2Go (select platforms only)
Communication/connectivity
HP Velocity (select platforms only)
Microsoft products
Buy Office
Skype (not available in China)
Manageability
Discover HP Touchpoint Manager
note: |
HP Value Add Software
HP ePrint Driver with JetAdvantage
HP Hotkey Support - CMIT
HP Recovery Manager
HP Recovery Disc Creator (Windows 7 only)
HP Support Assistant
HP Jumpstart
Foxit PhantomPDF Express (Windows 7 only)
Security
Trusted Platform Module (TPM) 2.0
Security cable slot
Microsoft Security Essentials (Windows 7 only and opt-in and internet connection required for updates)
Microsoft Defender
HP WorkWise (requires Bluetooth and available in August)
Specification
80 PLUS Bronze
180 W active PFC;
82/85/82% efficient at 20/50/100% load (115 V)
310 W active PFC; 82/85/82% efficient at 20/50/100% load (115 V)
Operating voltage range
90 – 264 VAC
Rated voltage range
100 – 240 VAC
Rated line frequency
50/60 Hz
Operating line frequency
47 – 63 Hz
Rated input current
180 W/2.3 A
310 W/4 A
Rated input current with energy efficient
power supply
180 W/2.3 A
310 W/4 A
note: |
DC output
+12.0 V
Current leakage (NFPA 99: 2102)
Less than 500 µA of leakage current at 120 Vac with the ground wire disconnected, as required for Non-patient Electrical Appliances and Equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Less than 100 µA of leakage current at 120 Vac with the ground wire intact with normal polarity, as required for Non-patient Electrical Appliances and Equipment used in a patient care facility or that contact patients in normal use. Per section 10.3.5.1.
Power supply fan
70 mm variable speed
Power cord
1.83 m (6.0 ft)
Specification
Dimensions (W x D x H in vertical orientation)
Chassis configured with (1) HDD and (1) ODD
17.0 x 27.41 x 33.80 cm (6.69 x 10.79 x 13.31 in)
Packaged configured with (1) HDD and (1) ODD
49.91 x 38.99 x 29.79 cm (19.65 x 15.35 x 11.73 in)
System weight configured with (1) HDD and (1) ODD
5.45 kg (12.01 lb)
Packaged weight configured with (1) HDD and (1) ODD
7.79 kg (17.17 lb)
Specification
Preinstalled (Windows)
Windows 10 Pro 641
Windows 10 Pro 64 (National Academic License)3
Windows 10 Home 641
Windows 10 Home Single Language 641
Windows 7 Professional 64 (available through downgrade rights from Windows 10 Pro)2,4
Preinstalled (other)
FreeDOS 2.0
NeoKylin Linux 64
Web-supported
Windows 10 Enterprise 641
Windows 7 Enterprise 644
note:In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.1Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.2This system is preinstalled with Windows 7 Pro software and also comes with a license and media for Windows 10 Pro software. Only one version of the Windows software can be used at a time. Switching between versions requires you to uninstall one version and install the other version. You must back up all data (files, photos, etc.) before uninstalling and installing operating systems to avoid loss of data.3Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary; for more information, see Windows 10 Pro Education features.4Only available with 7th generation Intel processors.
Specification
Certifications
EPEAT Silver 1.0
note: GS mark (for 290 G1)
CECP (China only)
SEPA (China only)
WEEE (Waste, electric and electronic equipment)
ENERGY STAR 6.1
EuP Lot 3
CEL Level 1
FCC
UL
RoHS 2.06 compliance
