Specification
Model
L1K59A4
Type
23.8-inch AHVA with LED backlight
60.44 cm (23.8 in) widescreen; diagonally measured
Panel active area (W x H)
526.85 x 296.35 mm
Resolution
2560 x 1440 at 60 Hz
Aspect ratio
16:9
Viewing angle
Up to 178° horizontal/178° vertical (typical)
Brightness
300 cd/m2
Contrast ratio (typical)
1000:1 Static; 5,000,000:1 Dynamic (DCR)
Response times
8 ms gray to gray
Pixel pitch
0.2058 x 0.2058 mm
Pixels per inch (PPI)
123.4 DPI
Backlight lamp life (to half brightness)
30,000 hours minimum
Color support
Up to 16.7 million colors with the use of FRC technology
Color gamut (typical)
sRGB
