HP ProDisplay P221 21.5-inch LED Backlit Monitor has diagonal viewable area display with 1920 x 1080 resolution.
Feature
Model
P221
Spare part number
710898-001
Type
TN (Twisted Nematic) LED Backlit LCD
54.61 cm wide screen (21.5 inches wide screen)
Viewable image area
(diagonal)
Backlight
LED
Tilt capability
-5° to +25°
Pivot Rotation
No
Video signal input
SVGA (analog), DVI with HDCP support
On-Screen Display (OSD) adjustments
Several languages for easy setup and screen
optimization
Swivel and height adjustment capabilities
360°
Security Lock-Ready
Yes
Specification
Power source
100 – 240 V ac 50/60 Hz
Typical power consumption
22 W
Maximum
28 W
Sleep
0.35 W
Specification
54.61 cm (21.5 in.widescreen)
Type
Tilt
-5° to +25°
Swivel
No
Specification
Maximum graphic resolution
Optimum graphic resolution
Text mode
720 × 400
Horizontal frequency
24 to 94 kHz
Vertical refresh rate
50 to 76 Hz
Specification
Dimensions (H x W x D)
Highest position: 51.8 x 16 x 37.9 cm(20.39 x 6.3 x 14.92 in)
Maximum weight (Unpacked)
4 kg (8.8 lb.)
Specification
Operating
Non-operating
