Before uninstalling the printer driver, ensure that there are no jobs in the print queue. Follow the steps mentioned below to check and delete any document in the print queue.
In the Devices and Printers window, printers installed on the computer will be listed. Before removing the printer, make sure no print jobs are in the print queue.
From the Start menu, click on Control Panel. (Alternatively, click on Devices and Printers option on start menu to access printer directly.)
From Control Panel (If View by is set to Category), double click on View devices and printers found under Hardware and Sound.
From Control panel (If View by is set to Small or Large Icons), double click on Devices and Printers.
To check if there are any print jobs in the print queue, click on the printer that needs to be removed and click on See What’s Printing button.
This will open the print queue of the printer that is being removed. If there are no print jobs in the queue, no print jobs will be listed. If there are print jobs on in the queue then a list of all print jobs will be listed that are pending.
If there print jobs in the queue, close all the application that are open on the computer, then click on Printer button and click on Cancel All Documents options. This should clear all print jobs from the print queue.
Alternatively highlight each print job and manually press Delete key on the keyboard.
If any of the print jobs are not deleted, then disconnect the printer communication, restart the computer and printer. Once the computer is restarted, continue with the procedure.
Once the print jobs are deleted or cancelled, the print queue should be empty.
Once the Print queue is empty, click and highlight the printer to be removed and click on the Remove Device button.
Alternatively, left-click on the printer that needs to be removed, then right-click on the printer icon and click on Remove Device option.
This would remove the printer icon from printers and faxes list.
