8VZ08PA
HP Notebook - 14-ck2009tu
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz base with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
4 GB DDR4-2666 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics
1 TB 5400 rpm SATA
14" diagonal HD SVA BrightView WLED-backlit, 220 nits, 45% NTSC (1366 x 768)
Realtek 802.11 a/b/g/n/ac (1x1) and Bluetooth® 4.2 Combo
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
33.5 x 23.4 x 1.99 cm
Starting at 1.47 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
