To install a scan driver, follow these steps:
note:Make sure to download the latest scan driver.To download the latest drivers and software, go to Software and Drivers, type your printer model in the text box, and then click the Driver tab to view the latest driver. Download the scan driver if the latest version is not downloaded.
After downloading the latest scan driver, click Run to start the installation wizard.
Select to accept the End User License Agreement and Using Enhanced Features and Participating in Printer Usage Information Collection Program check boxes, and then click Next.Figure : Agreement for installing software
Make sure to connect the printer to a USB or network, and then click Next.Figure : Connecting the printer
Depending on how your printer is connected, select one of the following printer connection options, and then click Next.
Direct connection using a USB cable Printer connected with a USB cable to a computer.
Network connection Printer connected wirelessly or wired to a router/access point.
Configure the wireless network connection using USB cable Set up a printer connected wirelessly to a USB cable.
Figure : Printer Connection Type -
Select your printer, and then click Next from the list of connected printers.Figure : Printers Found
Select the components required for installing, and then click Next.Figure : Software install selectionA progress bar displays when the components are installed.Figure : Progress bar during software installation
When the setup is completed, click Finish to close the wizard.
To register your printer, select the On-line Registration check box.Figure : Setup completion
