The following information describes how to clear a paper jam in the 2,100-sheet high-capacity tray. When a jam occurs, the control panel displays one of the following messages and an animation that assists in clearing the jam.
13.A3.XX Jam in Tray Y, where Y equals the tray number assigned to the HCI
13.A4.XX Door Open Jam
Open the 2,100-sheet high-capacity input tray.Figure : Open the tray
Remove and discard any damaged sheets.Figure : Remove any jammed paper from the tray
Remove the stack of paper from the tray.Figure : Remove the stack of paper from the tray
Lift the tray up and then pull it straight out to remove it.Figure : Remove the tray from the printer
If any jammed paper is in the feed area, pull it down to remove it.Figure : Remove any jammed paper from the feed area
Reinstall the tray, and then load full reams of paper into the tray. The tray holds 2,100 sheets of paper.
For best results, load full reams of paper. Avoid dividing reams into smaller sections.Figure : Reinstall the tray in the printer and then load a full ream of paper in the tray -
Close the tray.Figure : Close the tray.
