Display size
21.5"
Display size (diagonal)
54.6 cm (21.5")
Display type
IPS
Panel active area
18.74 x 10.54 in
Brightness
300 nits
Pixel Pitch
0.248 mm
Input connector
1 VGA; 1 HDMI 1.4 (with HDCP support)
Scan range (horizontal)
30-86 KHz
Scan range (vertical)
48-75 Hz
Color gamut
99% sRGB
Pixels per inch (ppi)
102 ppi
Screen treatment
Anti-glare
Onscreen controls
Brightness; Exit; Information; Management; Power control; Input control; Menu control; Image; Color
Resolution (maximum)
FHD (1920 x 1080 @ 75 Hz)
Curvature
Flat
Backlight type
Edge-lit
Recommended resolution
1920 x 1080 (FHD)
Aspect ratio
16:9
Contrast ratio
1000:1
Display contrast ratio (dynamic)
10000000:1
Response time
5ms GtG (with overdrive)
Panel bit depth
8 bit (6 bit + FRC)
Height adjustment range
No height adjust
Horizontal viewing angle
178°
Vertical viewing angle
178°
Display features
On-screen controls; AMD FreeSync™; Low blue light mode; Anti-glare
Tilt
-5 to +25°
Resolutions supported
640 x 480; 720 x 400; 800 x 600; 1024 x 768; 1280 x 720; 1280 x 800; 1280 x 1024; 1440 x 900; 1600 x 900; 1680 x 1050; 1920 x 1080
Bezel
3-sided micro-edge
Low blue light
Yes, Eyesafe® Certified
Hardness
3H
Flicker-free
Yes
External
Power consumption
19 W (maximum), 13 W (typical), 0.5 W (standby)
Power supply
100 - 240 VAC 50/60 Hz
