780F0AA
780D9AA
780D9AS
780D9E9
Display size
23.8"
Display size (diagonal)
60.5 cm (23.8")
Display type
IPS
Panel active area
52.7 x 29.65 cm
Brightness
300 nits
Pixel Pitch
0.28 x 0.28 mm
Scan range (horizontal)
30-210 kHz
Scan range (vertical)
60-165 Hz
Display colors
Up to 16.7 million colors supported
Color gamut
99% sRGB; 90% DCI-P3
Pixels per inch (ppi)
93 ppi
Screen treatment
Anti-glare
Onscreen controls
Management; Information; Exit; Input; Color; Image; Power; Menu; Gaming
Resolution (maximum)
FHD (1920 x 1080 @ 165 Hz)
Curvature
Flat
Backlight type
Edge-lit
Recommended resolution
1920 x 1080 (FHD)
Aspect ratio
16:9
Contrast ratio
1000:1
Display contrast ratio (dynamic)
10000000:1
Response time
1ms GtG (with overdrive)
Panel bit depth
True 8 bit
Height adjustment range
100 mm
Horizontal viewing angle
178°
Vertical viewing angle
178°
Display features
On-screen controls; Anti-glare; AMD Freesync™ Premium; Height Adjust/Tilt/Pivot; Gaming Console Compatible; HP Eye Ease (Eyesafe® certified)
Tilt
-5 to +23°
Resolutions supported
640 x 480; 720 x 400; 800 x 600; 1024 x 768; 1280 x 720; 1280 x 800; 1280 x 1024; 1440 x 900; 1600 x 900; 1680 x 1050; 1920 x 1080
Backlight lamp life
30,000 hours
Bezel
3-sided borderless
Viewable diagonal size
23.8" (60.47 cm)
Low blue light
Yes, HP Eye Ease (Eyesafe® Certified)
Hardness
3H
Flicker-free
Yes
Internal
Power consumption
40 W (maximum), 25 W (typical), 0.5 W (standby)
Power supply
100 - 240 VAC 50/60 Hz
