6W7N0PA
HP Laptop 15s-du1540TU
Intel® Celeron® N4120 (up to 2.6 GHz burst frequency, 4 MB L2 cache, 4 cores, 4 threads)
Intel® Integrated SoC
8 GB DDR4-2400 MHz RAM (1 x 8 GB)
Video graphics
Intel® UHD Graphics 600
128 GB SATA 3 TLC M.2 SSD
Optical drive
Optical drive not included
15.6" diagonal, HD (1366 x 768), micro-edge, BrightView, 220 nits, 45% NTSC
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.74 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Audio
Dual speakers
