HP Laptop 14s-dr2008TU Product Specifications
347A9PA
Intel® Core™ i3-1115G4 (up to 4.1 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 2 cores)
Intel® Integrated SoC
8 GB DDR4-3200 MHz RAM (1 x 8 GB)
Video graphics
Intel® UHD Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal, FHD (1920 x 1080), IPS, micro-edge, BrightView, 250 nits, 45% NTSC
Realtek RTL8821CE-M 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
32.4 x 22.5 x 1.79 cm
Starting at 1.47 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Dual speakers
