194Y9PA
HP Laptop - 15s-gu0001au
AMD Athlon™ Gold 3150U (2.4 GHz base clock, up to 3.3 GHz max boost clock, 4 MB L3 cache, 2 cores)
AMD Integrated SoC
Video graphics
AMD Radeon™ Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD, SVA, anti-glare, micro-edge, WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.74 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 6 hours
Video Playback Battery life
Up to 8 hours
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
