Figure : HP Elite Slice for Meeting Rooms G2
Specification
Preinstalled
Windows 10 IoT 64 Enterprise CBB
note: |
Specification
Intel Q170 supporting Intel Peripheral Control Hub for 7th Gen Core Processors,
featuring integrated Intel HD Graphics and Intel vPro Technology
Intel Core i5-7500T vPro¹
35 W
Up to 3.3 GHz maximum turbo frequency
2.7 GHz base frequency
6 MB cache
4 cores
4 threads
Intel HD Graphics 630
Supports DDR4 memory up to 2400 MT/s data rate
Supports Intel vPro Technology and Intel Stable Image Platform Program (SIPP)
Intel Core i5-7400T non vPro¹ (applicable only for HP Elite Slice for Meeting Rooms G2 for Skype Room Systems)
65 W
Up to 3.5 GHz maximum turbo frequency
3.0 GHz base frequency
6 MB cache
4 cores
4 threads
note:¹In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors or provide any Windows 8 or Windows 7 drivers.Multicore is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. Performance and clock frequency will vary depending on application workload and your hardware and software configurations. Intel numbering, branding, and/or naming is not a measurement of higher performance.
Specification
Integrated
Intel HD Graphics 630 with GT2 support
note: |
Specification
Type
DDR4-2400 (Transfer rates up to 2400 MT/s)
Maximum
32 GB capacity
Number of slots
(2) DIMM
Both slots are customer accessible/upgradeable, dual channel memory supported
Configurations
8 GB DDR4-2400 SODIMM (2 x 4 GB) (dual channel)
Specification
Solid state drives M.2 NVMe
128 GB PCIe NVMe M.2 Solid State Drive
256 GB PCIe NVMe M.2 Solid State Drive
SATA solid state drives, 6.35 cm (2.5 in)
128 GB SSD TLC SATA Drive
256 GB SSD TLC SATA Drive
note:For hard drives and solid state drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) of system disk is reserved for the system recovery software.
Specification
Type
Conexant CX20926 codec
Jacks, speakers, and modules
(1) Universal audio jack (with re-tasking)
(4) 2W internal speakers (with dual passive radiator stereo sound system)
HP Audio Module 2.0 (integrated)
(4) Digital microphones
Specification
Ethernet (RJ-45)
Wired Intel i219LM GbE LOM
Wireless (optional and must be configured at purchase)
Intel 7265 ac 2 x 2 with Bluetooth non-vPro
Intel 8260 ac 2 x 2 with Bluetooth vPro
Intel 8260 ac 2 x 2 with Bluetooth non-vPro
HP Elite Slice for Meeting Rooms G2 for Intel Unite
Specification
Type (only for HP Elite Slice for Meeting Rooms G2 for Skype Room
Systems)
Sure Start 2.0 with private SPI flash
Active Health (Black box flight recorder)
Infineon TPM SLB9670 TPM 2.0/TPM 1.2
HP dual head keyed cable lock kit (optional and must be configured at purchase)
Specification
External in/out ports
(1) USB Type-C (USB 3.1 Gen 1, 15 W output)
(1) USB Type-A (USB 3.1, charging)
(1) USB Type-A (USB 3.1, S4/S5 wake)
(1) USB Type-C (Alternate mode DP, USB 3.1 Gen 1, 15 W output, 60 W input)
(1) DisplayPort
(1) HDMI (optional HP DisplayPort)
(1) RJ-45
(1) DC-in 7.4 mm (0.29 in) barrel
Internal in/out ports
(1) M.2 NVMe
(1) SATA
Slots
(1) M.2 2230 PCIe for WLAN
(1) M.2 2280 PCIe for NVMe SSD
Additional modules
HP Cable and Port cover
HP Center of Room Control
HP Video Ingest Module
HP Wireless Display Module (available in certain countries/regions and is optional)
VESA Mount (optional)
HP Wireless Display Module (available in select countries/regions only and is optional)
Specification
Keyboards
HP USB Business Slim Keyboard
HP USB Business Slim Keyboard (China only)
Mice
HP USB Optical Mouse
HP Mouse pad
HP USB Mouse (China only)
HP 1000dpi Laser Mouse
HP Mouse Pad
note:Keyboards and mice are optional or add-on features.
Specification
Type
65 W AC adapter with up to 85% efficiency
90 W AC adapter with up to 85% efficiency
Specification
BIOS
Absolute Persistence Module2
HP Wireless Wakeup
HP Velocity
HP Recovery Manager
HP Support Assistant (requires Windows and internet access)
HP Collaboration Keyboard Software
HP Notifications
Intel Unite Plus Lync Plug-in (specific to HP Elite Slice for Meeting Rooms G2 for Intel Unite)
Microsoft Skype Room Systems (specific to HP Elite Slice for Meeting Rooms G2 for Skype Room Systems
note:2Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Specification
Chassis
(H x W x D)
16.5 x 16.5 x 3.55 cm (6.5 x 6.5 x 1.4 in)
note: |
1.52 kg (3.36 lbs)
Color
Sparkle black color
