Z4Z35UA
HP Spectre x360 - 15-bl012dx
Intel® Core™ i7-7500U (2.7 GHz, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
512 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal UHD UWVA eDP Brightview WLED-backlit narrow bezel touch screen (3840x 2160)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 Thunderbolt™ 3 (Data up to 40 GB/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 USB 3.1 Type-C™ Gen 1 (Data up to 5 GB/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 (HP Sleep and Charge)
35.6 x 25.1 x 1.79 cm
2.01 kg
90 W AC power adapter
6-cell, 79.2 Wh Li-ion
HP TrueVision FHD IR Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
