Y8J08PA
HP Pavilion - 15-au134tx
Intel® Core™ i5-7200U (2.5 GHz, up to 3.1 GHz, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
NVIDIA® GeForce® 940MX (4 GB DDR3 dedicated)
1 TB 5400 rpm SATA
Optical drive
SuperMulti DVD burner
15.6" diagonal FHD SVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 USB 2.0; 1 RJ-45; 1 HDMI; 1 headphone/microphone combo; 2 USB 3.1 Gen 1
38.3 x 24.3 x 2.25 cm
2.04 kg
65 W AC power adapter
2-cell, 41 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
B&O PLAY; HP Audio Boost; Dual speakers
