The following information provides the procedures to install or replace a stapler/stacker accessory for the HP LaserJet Enterprise M806 and HP LaserJet Enterprise flow MFP M830.
note:To see a short video demonstrating this procedure, click here.
Before you begin
Use the following table to identify the correct accessory part number for the accessory, and then go to www.hp.com/buy/parts to order the accessory.
CZ994A
Stapler/stacker accessory with installation instructions
CZ995A
Stapler/stacker with 2/3 hole punch accessory with installation instructions
CZ996A
Stapler/stacker with 2/4 hole punch accessory with installation instructions
To replace an existing stapler/stacker, go to Step one: Remove the stapler/stacker.
To install a new stapler/stacker, go to Step three: Install the optional or replacement stapler/stacker accessory.
Required tools
No special tools are required to install this accessory.
note:If the product does not have a stapler/stacker installed and you are installing an optional stapler/stacker, go to Step three: Install the optional or replacement stapler/stacker accessory.
Turn off the product, and then disconnect the power cord.
Turn the product off, wait five seconds, and then remove the power cord before attempting to service the product. -
At the back of the product, disconnect the finishing accessory interface cable.Figure : Disconnect the accessory cable
Open the finishing accessory front cover. Release and hold the bottom handle first, and then release and hold the top handle. Hold both handles at the same time, and then slide the finishing accessory away from the product.
Failure to follow these instructions might damage the product.Figure : Release the finisher -
Completely remove the finishing accessory.Figure : Remove the finishing accessory
Step two: Unpack the optional or replacement stapler/stacker accessory
Unpack the stapler/stacker from the packaging.
note:Remove all tape and packing material from outside the accessory. Open all doors and remove all tape and packing material from inside the product.
For recycling information, go to www8.hp.com/us/en/hp-information/environment/product-recycling.html.
note:HP recommends responsible disposal of the defective stapler/stacker.
Remove all of the shipping tape from outside the accessory.Figure : Remove the shipping tape
Open the front door of the accessory, and then remove all of the shipping tape and packing materials from inside the accessoryClose the front door.
Make sure that you remove all of the shipping material from inside the accessory.Figure : Remove the shipping tape and packing materials
If you have not already done so, turn off the product and disconnect the power cord.
Attach the accessory to the product.Figure : Attach the accessory
Use the adjustment wheels on the accessory to align that accessory with the edge of the product.
If the accessory is not correctly aligned with the product, you might experience excessive paper jams.Figure : Align the accessory and the product -
If you are installing an optional accessory for the first time, at the back of the product remove the accessory interface cable cover.Figure : Remove the accessory cable cover
Connect the finishing accessory interface cable.Figure : Connect the accessory interface cable
Connect the product power cord, and then turn on the product.
Step four: Parts return
The following URL provides information on how to return parts to HP for reuse and recycling: Product return and recycling
Step five: Configure the default hole punch location
From the Home screen on the product control panel, scroll to and touch the Administration button.
Open the following menus:
Stapler/Stacker Settings
Hole Punching
Select a hole punch location from the list of options, and then touch the Save button. The following hole punch options are available for either a 2/3 Hole Puncher or 2/4 Hole Puncher:Hole punch location2/3 Hole Puncher2/4 Hole PuncherNoneTwo left or topTwo leftTwo rightTwo topTwo bottomThree leftThree topThree rightThree topThree left or topFour leftFour rightFour topFour left or top
Not all options are available. Available options depend on whether the hole punch accessory is a 2/3 or 2/4 hole puncher.
note:To use the hole puncher, load Letter or A4-size paper with the long edge of the paper along the right edge of the tray (long-edge feed).
Step six: Configure the default staple location
Stapling
Select a staple location from the list of options, and then touch the Save button. The following staple options are available:
None
Top left
Top right
Two left
Two right
Two top
Two top or left
